Old 03-05-2009, 11:57 PM   #1
SoupNazi
SoupNazi is on a distinguished road
Default rookie question
Having never used a dial bore guage, I bought one, but I can not figure out how to use it. Should I be using the 3.2" rod with the .05 washer attached, or should it be with the .10 washer?
Add to SoupNazi's Reputation
Rate the quality of this post and help SoupNazi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SoupNazi is offline   Reply With Quote
Old 03-06-2009, 12:20 AM   #2
SoupNazi
Default Re: rookie question
I can't spell bore gauge correctly I guess.
Old 03-06-2009, 12:32 AM   #3
westwind999
1999 SW1
A picture would be helpful. (or maybe a make and model, link etc)
Old 03-06-2009, 01:29 AM   #4
SoupNazi
sorry, not sure if it is big enough.
Old 03-06-2009, 03:09 PM   #5
Set the total gauge larger than the hole and do the math. Use the 3.2 and the 0.10 spacer under the black nut. Zero out the indicator and then gently push the indicator pin to verify the mechanism is zeroed. place it in the bore and get the max deflection at your measurement point, that will be straight up and down position. Subtract that reading from 3.3000, thats the bore diameter at that point.
That is the same unit that I use.
Old 03-06-2009, 03:27 PM   #6
Gerry Proctor
2008 Astra XR
2008 SKY Red Line
Never tired that method. I always set the gauge with a mic. I'll have to try it to see how it works out.
Old 03-06-2009, 03:58 PM   #7
It works. Or you can back off the zero on the dial indicator so the actual new bore diameter is the zero point and then just read the deviation. That is nice but is real easy to foul up and ruin a block.
Old 03-06-2009, 09:18 PM   #8
SoupNazi
Thanks for the tutorial, if I can't figure it out I'll quit.
SL2 Lifter Knock (rookie goof) wcryle01 S-Series Tech 3 11-24-2008 08:25 PM
Rookie rebuild mistake SoupNazi S-Series General 3 08-26-2008 05:04 PM
Newbie Question - Size of Air condenser compared to radiator? Also airbag question. 2002SaturnMan S-Series General 9 04-18-2006 09:53 AM
Ring job question and timing chain question Preachermannn S-Series General 5 03-10-2005 02:40 PM
Question on replacing differential cover gasket ( non-Saturn question) Mark G Miscellaneous Tech 3 10-27-2002 01:50 AM
