Old 09-24-2008, 10:40 PM   #1
sl2ner08
sl2ner08 is on a distinguished road
Default problem scanning codes
i have an obdII scanner and when i plug it in i get no response to the unit at all... won't even power on...
now backround info, i have recently swapped tranny to a 5 spd so i did passlock relearn on a 5 spd computer, would this have anything to do with it?
sl2ner08 is offline   Reply With Quote
Old 09-24-2008, 10:47 PM   #2
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Default Re: problem scanning codes
You may not have power to the obdii port. Check your fuses.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Old 09-24-2008, 11:03 PM   #3
sl2ner08
whiich fuse?
Old 09-24-2008, 11:11 PM   #4
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Check the Red 10 amp "Body" fuse on the interior fuse panel. Its right above the fuel pump relay, its the left fuse on the bottom row of two fuses. That paticular fuse controls the Dome Lamp, Luggage Compartment Lamp (Sedan/Coupe), Power Mirrors, Map Lamps, Liftgate/Decklid Release Switch, Power Door Locks, and Datalink Connector
Mike
-1991 Turbo SL2.
Codes not getting problem? caesar_salad S-Series Tech 8 08-22-2008 05:48 PM
scanning tool '93 sc2 IBEME S-Series General 4 10-21-2007 04:27 PM
Thoughts On This Real Time Scanning Tool Mike1969 S-Series General 5 06-15-2006 05:29 PM
P0113 and P0341 problem codes msubobbo S-Series General 6 03-02-2006 04:16 PM
Scanning ABS codes Hiddenlites S-Series Tech 6 04-13-2003 06:36 PM
