Old 09-28-2020, 11:33 AM   #1
timl865
timl865 is a splendid one to beholdtiml865 is a splendid one to beholdtiml865 is a splendid one to beholdtiml865 is a splendid one to beholdtiml865 is a splendid one to beholdtiml865 is a splendid one to beholdtiml865 is a splendid one to behold
Default 97 sc2 dies on highway
help.... my 97 sc2 with 100k miles died on the highway. Pushed it off and towed it home. It sat for a week and tried it again and it started.. put some gas in it and went to the store. Died again. Waited overnight and it started just enough to get home and she died right in front of my house. I hear the pump energize.. anyone have any ideas? Thanks!
Tim.
timl865 is offline   Reply With Quote
Old 09-28-2020, 11:51 AM   #2
Waiex191
Waiex191 is just really niceWaiex191 is just really niceWaiex191 is just really niceWaiex191 is just really niceWaiex191 is just really nice
Waiex191's Avatar
Default Re: 97 sc2 dies on highway
I'd check for spark when it dies. Or if you have a Bluetooth OBD check for RPM when it is cranking. The classic failure for a CPS is it generally stops working when hot. That is a possibility.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 10-04-2020, 05:09 PM   #3
timl865
I changed the crank pos sensor and it still dies. I pulled off the left 2 wires from the coils and no spark. Control module?
Old 10-04-2020, 06:32 PM   #4
billr
Put a (metal) paper-clip on one of those coil terminals to close the gap to the other coil terminal down to about 1/2"; then check for spark again. The distance for coil terminal-to-terminal is a bit too wide for a reliable test. And, of course, do the same test on the other coil.
Still no spark, then check for injector pulses with a meter or 'noid light. Just looking for "wet plugs" is also not reliable to determine if the injectors are pulsing.
Do you hear the fuel pump come back on when cranking? The initial 2-second run at key-on is meaningless for the diagnosing needed right now.
Old 10-04-2020, 08:35 PM   #5
Check for spark on both coils when starting. Lack of spark on all four would point to the ignition control module. Intermittent problems are sometimes more difficult to pinpoint. .
One method to test for spark and fuel; spray starting fluid into the throttle body.
Old 10-05-2020, 03:10 PM   #6
timl865
Is there a way to test the ecm?
Old 10-05-2020, 03:28 PM   #7
billr
Not really, not a full functional test. We can guide you on some tests of PCM inputs/outputs, but it will require far more skill than just checking for spark or injectors pulses. Let's get past those first...
To do much PCM testing you would need a specialized signal-generator, or slave CKP wheel/sensor, to provide the "7X" CKP signal.
Old 10-05-2020, 05:39 PM   #8
timl865
It was replaced 2 years ago with a bwd brand from advance. I warranted it out with a new one. Keeping my fingers crossed. Thanks for the input
Old 10-07-2020, 02:20 PM   #9
timl865
So I replaced the ecm under the coils and took off the left 2 wires and cranked it. This time there was strong arcing between the posts so I hoping that was the problem.. the last time there was nothing! Thanks for the suggestions! You guys are always a big help..
Tim
Old 10-07-2020, 05:07 PM   #10
I think you meant icm, ignition control module, that has both coils mounted to it. The ecm ( engine control module) or pcm (powertrain control module) manage the entire EFI system.
Did replacing the icm get your engine running again?
Old 10-09-2020, 01:09 PM   #11
timl865
YES ignition control mod.. thats it. So far so good thanks!
2002 Saturn SL jerking at highway speed, occasionally dies clinteastwood S-Series Tech 6 09-07-2018 09:00 PM
97 sw1 dies on highway M_Metzger1114 S-Series Tech 11 05-01-2017 04:56 PM
Die out on highway Ccrussell S-Series Tech 13 09-14-2016 04:30 AM
2001 LW dies on highway... dodo L-Series Tech 7 03-11-2015 02:00 PM
98 SC2 idles funny, dies, oil in spark plug well, fixed that, still dies, etc. Kpendrgn S-Series Tech 18 02-03-2007 10:58 PM
