Old 09-25-2020, 05:25 PM   #1
Pitcher
Pitcher's Avatar
Question Steering Wheel vibrates 65-80MPH. Clears Up Above That. (??)
My invincible '98 SC2 Red Hot.
Steering wheel shaking a bit from 65-80MPH. Clears up at 85-95MPH.
Has 4 TigerPaws about 20k on them.
Fronts were 28psi.
Rears were 26psi.
Put 40psi in the fronts & 35psi in the rears.
Vibrations now on & off every 4-5 seconds at the same speeds. (!!)
Rebalanced at the same place. No change.
Rebalanced the front tires at a different place.
One was dead on, one was off .75.
Still vibrates as before the re-balance.
ALL front end parts are tight & ALL new bushings put in.
Thoughts?? I have mine, but want to hear yours first.
Owned 4 other S-Series.
Old 09-25-2020, 10:07 PM   #2
toggenburg
toggenburg's Avatar
Default Re: Steering Wheel vibrates 65-80MPH. Clears Up Above That. (??)
Could be just a harmonic thing at that speed range.
Some vehicles exhibit this more than others.
In my neck of the woods, attempting to hit 75, or up to 95 would be very risky to ones drivers license. Kinda called reckless driving and automatic loss of license IIRC.
Old 09-25-2020, 10:20 PM   #3
Waiex191
Waiex191 is just really niceWaiex191 is just really niceWaiex191 is just really niceWaiex191 is just really niceWaiex191 is just really nice
Waiex191's Avatar
I'd swap front and rear tires and see what happens. Could be a bad tire.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 09-25-2020, 10:20 PM   #4
billr
Swap wheels front-to-rear; let's see what that does.
How about wheel alignment, has that been checked lately?
My guess? A bad tire, ply separation or belt not quite in right place. There are some kinds of imbalance that can't be easily detected or corrected.
Can you get somebody to drive alongside you and see if the front wheels are waggling side-to-side (shimmy) when this happens?
Old 09-25-2020, 10:29 PM   #5
toggenburg
toggenburg's Avatar
Tried to edit, but had timed out.
Can also be the rear tire balancing affecting the entire vehicle's harmonics.
Old 09-25-2020, 10:45 PM   #6
sc2 saturn
sc2 saturn will become famous soon enough
id say wheel balance issue try and manual balance them u can youtube videos on this sometimes the balance machines at tire shops get off balance but still say they are balance, or add balance sand inside the tire which will find the spot and make it balance
sc2 saturn is offline   Reply With Quote
Old 09-26-2020, 08:43 AM   #7
Pitcher
Pitcher's Avatar
Re-Balanced 3 total times at 2 different shops.
One-at-a-time front to back swap was 1st on my list.
Odd the air pressure affected harmonics of the issue, thus the post.
Old 09-26-2020, 10:19 AM   #8
This might be a case where a simple spin balancer doesn't show an issue that a road force balancer would.
Do you have any other wheel/tire combos to bolt on? That'd eliminate half the things to look it, if the issue stays with the "new" tires then it's an issue car side...otherwise something is funky with the "old" tires.
Old 09-26-2020, 11:17 AM   #9
billr
No, it is not at all odd that tire pressure affected it. Tire pressure is a big factor in determining the "springiness" of the system. Harmonic vibration is all about mass-force-spring relations.
Old 09-26-2020, 03:41 PM   #10
bumpdraft
bumpdraft's Avatar
1998 SW2
Please post the resolution, when you get there.
You know what they say:
Barbecues, tea kettles, gobs of axle grease
There comes a time for every man to sail the seas of cheese
Now, life's a bowl of bagel dogs, but there are unpleasantries
Cold toilet seats, dentist chairs and trips with bad tires.
Old 09-27-2020, 05:21 PM   #11
imaddicted2u
imaddicted2u's Avatar
2008 AURA XE
I had a similar issue with my Aura. When the tire shop tried to balance them, one couldn't be balanced. When they broke down that tire, they found handfulls of rubber crumbs from broken belts. Could be dangerous.
Old 09-27-2020, 06:34 PM   #12
billr
The tires have been balanced three times, but at what rpm? They need to get up to 900 rpm or more to get into the range where you are having a problem. I think most consumer-oriented tire shop balancers don't spin nearly that fast.
Old 09-28-2020, 03:37 AM   #13
454cid
Really 75mph? 70mph is the speed limit on the highways here, and 75mph will often have you getting passed by others. The police won't even notice you at 75.
For the OP, I'd suspect something like a belt in the tire, but I'd also look at the rotors, and front wheel bearings. Maybe something in between the rotors and hubs? When you check the front end, make sure the suspension isn't at full droop as it may be keeping things from wiggling with spring pressure.
At a former job we had a work van that was starting to death wobble while braking and it ended up being a front tire that had gone bad.... broken/shifted belt, I'd guess. It didn't look bad, but once replaced the problem was gone.
One more thing..... is it always on the same road?
1999 Chevy K3500
Old 09-29-2020, 03:28 PM   #14
RobertGary1
RobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of light
If swapping tires and balance doesn’t fix it I’d check for bad ball joints.
-Robert
Old 09-30-2020, 03:15 PM   #15
Pitcher
Pitcher's Avatar
It vibrates on many different roads.
Will for sure let everyone know what it was once found.
I counted 7-8 seconds of vibration... followed by 7-8 seconds of stability.
Old 09-30-2020, 03:18 PM   #16
billr
Do you understand that it would be helpful to know if this is a shimmy/waggle or vibration/hop? The causes/fixes may be far different, depending on which it is.
Old 09-30-2020, 04:17 PM   #17
Pitcher
Pitcher's Avatar
Steering wheel shakes side-side 1/4" for 7-8 seconds.
Then it stops shaking side-side for 7-8 seconds.
On and on and on.... Day after day.
Cool tires, warm tires, or hot tires.
Old 09-30-2020, 04:58 PM   #18
billr
That sounds more like a "shimmy" to me, and I would be focused on alignment or tire damage more than wheel balance or suspension looseness. I can appreciate the difficulty in driving at 65+ with somebody "in formation" alongside, but if they could see the wheels waggling we could confirm. Shakes/vibrations are often hard to properly identify; the steering wheel probably could shake side-to-side even if this is not shimmy.
Old 10-03-2020, 12:12 AM   #19
PrestonIII
PrestonIII is a jewel in the roughPrestonIII is a jewel in the roughPrestonIII is a jewel in the rough
It's not always about balance.
A tire that is out-of-round can still balance up, but can hop like mad going down the road. You can balance a rotating square!! Tire pressure and position placement of the offending tire can change the amount of shake and the speed (frequency) that it shakes at.
When you have a shake that comes and goes every few seconds, it's usually a "beat frequency" between two tires bouncing. At one point, each tire's shake cancels the other out so there's no shake, and in a few seconds the tire's shake will actually add to each other (reinforce each other) causing the car to shake. Eliminating one of the offending tires or moving JUST ONE of them to a different placement on the car can often drastically change the beat frequency.
Preston
PrestonIII is offline   Reply With Quote
Old 10-23-2020, 06:00 PM   #20
Pitcher
Pitcher's Avatar
Here's the follow-up.
Place that did original rotate & balance wanted to rotate the fronts to the backs again.
Said Ok. That resolved the steering wheel shaking completely.
So the issue is at the back, but cannot feel anything.
Think I'll get at least the rear ones Road Force Balanced.
Something in the steering snapped, steering wheel turns around and around, tires wont BullyCanadian Vue Tech 23 02-11-2020 01:57 PM
Exchanging 2004 steering wheel for 2007 steering wheel Northerner Vue General 0 12-16-2017 09:32 PM
Replacing steering wheel - how do I make sure coil behind steering wheel is ok? vikasevan S-Series Tech 2 12-29-2014 01:32 PM
leather steering wheel question/steering wheel comment 2006 ion2 Ion General 4 04-29-2010 07:27 PM
Steering wheel vibrates at high speeds? TylerD Ion General 23 09-17-2004 11:12 AM
