Old 09-23-2020, 11:13 PM   #1
DevinPotter
DevinPotter is on a distinguished road
1998 SL1
Default I Need 98 Saturn SL1 Lifter oreintation/step by step procedure ?
Hi I need some info for a 98 saturn sl1 1.9L L4 SOHC automatic im replacing my lifters and I need to know what orientation/ faceing direction they go in I was planning on putting the lifter hole next to the oil passage coming out of the head any tips or step by step would be awesome thanks
DevinPotter is offline   Reply With Quote
Old 09-24-2020, 07:56 AM   #2
Highmile
Highmile's Avatar
Default Re: I Need 98 Saturn SL1 Lifter oreintation/step by step procedure ?
Which way the oil holes face doesn't matter. What does matter is the guide plate on top of the head that keeps the lifters in the right orientation.
Why are you needing to replace the lifters? They are a part that rarely ever fails.
Highmile
'95 SL1 715k and counting
Old 09-24-2020, 12:11 PM   #3
DevinPotter
1998 SL1
Highmile
I took the lifters out and the were all stuck down in gumed up the oil in them was all burnt black with varnish on the plungers I cleaned them up and they freed up but the all had different resistant pressure some hard to push some not not even through out the set I figure new one would be good I took a pictures to replace them back in the right bucket but I mixed up two of them and I was like im going to buy new ones and I did Im waiting for them in the mail I know you can put new lifters on a old cam I heard that the orientation matters I heard it on this forum. But now I got conflicting info some one said the face to the passenger side I hope some one has a defendant answer maybe you you wouldn't by chance have like a alldata subscription an confirm. And for the lifter plate guids they look to be the same any direction same cimetry can you confirm on that. Also my car has 280+ miles I changed out my valve stem seals as well just throwing that out there they they were shot oh and those lifter im think I face the other holes torwds the oil passage instead of on opposite side in bucket coming from head passage ways I think it may be better IMO whats your OP ?
Old 09-25-2020, 01:09 PM   #4
Highmile
Highmile's Avatar
I don't think it matters which way they go. In the Saturn motors I've built I've never even given them a second glance.
Highmile
Old 09-25-2020, 01:27 PM   #5
AFAIK the only orientation that matters is the flat side goes up and the hollow side goes down.
Old 09-26-2020, 02:02 PM   #6
DevinPotter
1998 SL1
Thanks everyone. For there opinion. Very valuable to me ! I Got one more question. Do you guys think there be any better oil flow / less ware / quiter engine air in oil at start maybe bleeds air if it forced around the lifter etc. if the oil passage ways were closer together again thanks you guys
Old 09-26-2020, 02:39 PM   #7
Waiex191
Waiex191 is just really niceWaiex191 is just really niceWaiex191 is just really niceWaiex191 is just really niceWaiex191 is just really nice
Waiex191's Avatar
Nope. Don't over think it.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 09-28-2020, 11:46 AM   #8
DevinPotter
1998 SL1
Originally Posted by waiex191 View Post
nope. Don't over think it.
lol 10 4
Old 10-06-2020, 12:29 AM   #9
DevinPotter
1998 SL1
Hey everyone I just wanted to let you know I got the parts installed and everything is all good im happy
How To Remove Outter Door Panels & Lube locks etc - Step by Step 1997 SW2 w/ pictures mrbios How-To Library 19 05-03-2019 01:04 AM
Step by step on replacing the entire wiring harness on a 95 SL1 SOHC Meistersinger S-Series Tech 1 08-08-2014 10:35 PM
Step-By-Step - 3.5L Throttle Body Coolant Bypass (with pictures) burnout Vue Mods 14 01-21-2010 04:12 PM
Is there a "step-by-step" how to" procedure to change the ATF fluid? kim_lombard Vue Tech 0 07-25-2007 11:24 PM
Input shaft nut step-by-step procedure MSgtEgress S-Series Tech 4 09-26-2006 06:36 PM
