Go Back   SaturnFans.com Forums > Categories > General Saturn Discussion
Old 12-08-2019, 05:51 PM   #1
Wallyo
Wallyo is on a distinguished road
1997 SW1
Default Did I cause engine damage?
I did a stupid thing. I changed the oil in my Saturn, started the engine to check for leaks, got distracted, came back and notice loud valve lifter clicking and realized I didn't put in the new oil! I turned the engine off after about a half minute of running it dry. When I put in the new oil and started it again, it went well, except that there's now one lifter clicking pretty loud, and I can't say for sure if that's a new sound. Do you think I did damage? It's a 97 SW1, about 185,000 miles.
While we're at it, does anyone know where the engine coolant level sensor is? The radiator and reservoir are full but the coolant warning light flashes as soon as I start the engine. I think it's a faulty sensor, but can't find it.
Finally, why do I have to add oil so often? I don't see any oil spots on the driveway, and there's not a trace of blue smoke or smell in the exhaust.
I love this site, and thanks again for the many good tips on keeping my Saturn on the road.
Wallyo is offline   Reply With Quote
Old 12-08-2019, 10:19 PM   #2
Default Re: Did I cause engine damage?
I think you should repost this again in the S-series Tech forums. You'll probably get immediate replies.
Old 12-11-2019, 02:12 PM   #3
+1, post in the model-specific forums.
You coolant level sensor is a simple float, located in the surge tank (some folks call it the reservoir) located on the passenger inside fender.
First, make sure that the tank is really full - the minimum cold level is at about the halfway mark on the tank. Full is at the tank seam, almost to the top of the tank.
If that doesn't fix it, drain and remove the tank, add a dash of dish soap and warm water using your fingers to plug the holes, and give it a decent shaking. That should unstick the float - you should hear it rattle / move. Rinse, install, and refill
Old 10-22-2020, 05:42 AM   #4
minayang
minayang is on a distinguished road
Are you sure this is a good idea? I think it's flawed
word unscrambler
minayang is offline   Reply With Quote
Tags
coolant light, lifter noise, no oil
2003 Vue - low oil engine damage? SLMike Vue Tech 10 06-03-2011 04:15 PM
engine oil pan saturn l200 2.2l damage guillermoqr2000 L-Series Tech 3 03-09-2011 02:10 AM
has any1 thrown a timing chain and NOT had engine damage on SOHC sl1 type engine? MacExperts S-Series Tech 14 09-21-2006 06:04 PM
Damage to Engine Cradle karaoke diva S-Series General 1 10-21-2005 05:13 PM
SC2 Maroon w/ tan interior. no engine, front end damage DiehlLane Classifieds 11 01-11-2005 08:38 PM
