Old 05-07-2019, 05:34 PM   #21
Designie
Designie is on a distinguished road
2006 VUE Red Line
Default Re: 06 Redline will not run/idle while cold
Well I'm not sure if I'm doing something wrong. I have the sensor out, and I do not get any resistance between any of the 6 contacts on the switch. I started with 1 & 2, 1 & 6 then 2 & 6. Nothing. Then touched every combination of 2 contacts. Should I be seeing some resistance reading?
Designie is offline   Reply With Quote
Old 05-07-2019, 06:02 PM   #22
Yes, there should be some resistance between 1&6, 1&2, 2&6. Whenever using a multimeter for resistance measurement, there are at least two resistance ranges to select from. I usually touch both probes together and expect 0.00 or 000 on the display - a short circuit with zero resistance. Most meters I use show a tiny bit of resistance from metal probes, 0.002. This is acceptable. Testing resistance function by touching probes together and seeing a displayed reading ensures the multimeter is working. This might described as a baseline test. Then measuring a sensor is next. Keep in mind - crank sensors should measure in hundreds of ohms so the higher value resistance function should be selected on multimeters. Good multimeters will display 'ERR' or something similar if the selected range is incorrect.
Test the other sensor as each sensor should have at least one resistance value, ideally three. If no resistance is measured, this implies open circuits and would correlate with no engine run with a cold engine yet somehow work just enough to get the engine to run until it warms up(?). An open circuit/zero resistance means the sensor(s) is/are broken, internal circuits failed. If this is the case, replace it. If you like, rap it against the bench a few times and measure. Immerse it boiling water and measure. Cold, heat and vibration are the normal environment crank sensors operate in.
Old 05-07-2019, 07:05 PM   #23
Designie
2006 VUE Red Line
So I checked resistances, I was able to get a reading on all three circuits of each of the 2 sensors. It was really difficult to get it to read some of the contacts. It also seemed to make a difference which probe was on which contact. I thought resistance didn't matter which pin you had red on and which one you had black on.
So the readings were all pretty similar with the switch cold, except pins 1 & 2. The other combos were .68-.75 megaohms and 1 & 2 was 30. Then I submerged the sensor in boiling water and the readings fluctuated pretty wildly. So I'm not too confident in my measuring, but it definitely was reading something.
Voltage at the plug on the car was good on both circuits. 4.7v and 11.85v on both.
Old 05-07-2019, 08:47 PM   #24
Try measuring this sensor again. Leave it in the ice box, terminals facing up in a cup or soup can of water until frozen for an hour or so and measure resistance. Freezing cold, desert heat and engine vibration shouldn't affect resistance much with a slight variance. Be sure terminals are clean and free of conductive fluids like dirty oil. If resistances very greatly from freezing cold to boiling water, replace it. This isn't an inexpensive part. Rockauto lists a GM replacement at $125. All others are much higher.
Old 05-23-2019, 11:24 AM   #25
Designie
2006 VUE Red Line
Well after about as much testing as I could do with a meter, I cannot point to anything abnormal because really the readings for resistance are strange. I have had the sensor out of the car for a couple weeks. I've had the plug tucked up under the car to try and dry it out if maybe water of something was in there.
I reinstalled the sensor again yesterday, and no change. It ran horribly and I kept restarting it and keeping it running until temp was up. Once operating temp was up to normal, of course then it runs perfect.
I am stuck trying the old "Buy a new part and try it" road. Crazy how it would just happen to go bad at the exact time I changed the water pump. It's just so beyond coincidental.
I will report back when I try the new sensor.
Old 05-23-2019, 02:28 PM   #26
Part failure occurs in several ways. Random failure, failure while driving, failure after letting a vehicle sit overnight or after several days, weeks or months, etc. This isn't to make you feel better but my fuel pump died one state away from home with family on board. Another family member was called to meet us to bring us home. The next day was spent haggling with the tow company refusal to tow my car when insurance authorized the tow. Towed to my choice of garage and new pump went in. Another occasion was driving home from work when my crank sensor promptly died on a three lane highway. Coasted across three lanes to a nearby exit to a grassy area off the exit road and called a family member for help. As I waited, I tested the crank sensor (the tach died as one indication of a dead sensor while at highway speed (65 mph?) and measured incorrect resistance (much higher than expected). About 30-45 minutes later help arrived and I measured the sensor again with a better reading, started up (engine cooled down a bit) drove on local streets when the engine died again, coasting into a perfect parking spot. Returned later with a new crank sensor and drove home. Mechanical and electrical parts fail in their own time regardless of when or where.
Old 07-08-2019, 08:30 AM   #27
Designie
2006 VUE Red Line
So being very busy, I was not able to purchase the new sensor and get ti installed until now. And unfortunately, there is no change. The engine still runs like complete crap right up to the point that it reaches operating temp, then runs perfect.
I'm thinking I will try the coolant temp sensor next, pretty easy and inexpensive change out.
Old 07-08-2019, 06:11 PM   #28
I'm puzzled by zero change after replacing the crank sensor. I'm at a standstill, unable to think of the possibilities of this strange problem. Before throwing another part on the Vue, can you get hold of a reader? They're very handy with all the electronics, sensors and multitude of error codes to turn anyone around in circles. If you suspect the coolant sensor, the best way to check it is with a reader displaying before startup/cold engine temperature and after a full warmup. The cold engine temperature, preferably overnight, should show on a reader temps within a few degrees of ambient temperatures. The engine mass cooling off overnight should reflect the same coolant temperature as ambient temperature in your area. This is the baseline reference to go by with any vehicle temperature sensor using a cold engine and outside temperature for comparison.
Old 07-09-2019, 03:17 AM   #29
RobertGary1
RobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of light
Are you sure the timing belt was set correctly? Maybe you’re a tooth off.
-Robert
Old 07-09-2019, 03:22 PM   #30
Designie
2006 VUE Red Line
-Robert
I suppose it's possible that it could be off. It would surprise me that it would run perfect after warm up though. It would seem that it would run bad continuously then. I will get it to TDC and recheck the timing marks though.
I don't have access to a reader. I can ask around and see if perhaps I can come up with one. Not sure if that's part of the loan a tool program at auto parts stores?
Old 07-10-2019, 11:01 PM   #31
far2grumpy
far2grumpy's Avatar
As if water is not muddy enough - I'll stir the pot.
What if you have loose or broken wire at CKP? I've attached diagram if you have meter and time to run wires back to PCM.
I've attached description for DTC P0336 (is this code still active)?
I've also attached extract explaining cold engine start ... key ingredients are ECT and IAT (two IAT's are used - one in air filter box - next to PCM and the other is near throttle body).
And finally a file for hard start (ECT and CKP and other possibilities).
Old 07-26-2019, 09:58 AM   #32
Designie
2006 VUE Red Line
far2grumpy, you have been a tremendous help, I appreciate all of your information.
Unfortunately, things are going from bad to worse. I was about to start looking at the ECT sensor and the air temp sensor, I attempted to start the car to see if it would run, and of course it would not run very well. After about 4 times starting the car, I turned the key and....nothing. No click, no crank, nothing. I put the battery on the charger and even after it was fully charged, the key will do nothing. So possibly the starter decided to just now take a crap???
So that could be it for this vehicle. It is a sad case because it was my daily driver literally until I changed the leaking water pump. I just don't have the time to get to it, and now I'm just chasing issues on top of issues. Might be time to just give 'er up.
I really wanted to just sell it once I fixed the water pump to someone who could use a decent, cheap car. Now might have to give it away as a project or scrap. Kinda sucks.
Old 08-12-2019, 11:28 AM   #33
Designie
2006 VUE Red Line
So I jumped across the starter solenoid terminals from the positive battery cable to the smaller wire with the nut that was under a rubber boot. I assume that should crank the starter?
I hear a click, but the starter does not turn. So I am assuming the starter did in fact go bad.
Old 09-03-2019, 10:22 AM   #34
Designie
2006 VUE Red Line
Well, with renewed vigor I am back to working on this car. One way or another I am determined to get it fixed.
I had the old starter tested and is was in fact bad, so I bought and installed a new starter. I also got a new coolant temp sensor just to try. I figured $20, why not. After I had reinstalled everything, I started it up and sure enough the engine still runs really bad/stalls when it's cold. Once up to temp, it ran great. I took it out for about a half hour drive, and let it run for around an hour total.
So I verified the new timing belt is installed correctly, have a new crank sensor, new coolant temp sensor, new water pump. I am going to have the codes cleared and read any new codes to see what I can come up with next.
Old 09-03-2019, 02:15 PM   #35
It just occurred to me when you first mentioned replacing timing belt and water pump....... that this Vue has over 200k(?) miles? Replacing the starter is reasonable with high mileage.
Is your engine a 3.5L V6? If I'm not mistaken, these engines require periodic valve adjustment.
Old 09-03-2019, 04:41 PM   #36
RobertGary1
They do but in my experience the 3.5L will idle maybe very slightly rough (more like a slightly bad mount) but will throw a code for misfire. I've never seen one get so bad the car runs bad. The amount the valves change with wear is very subtle.
When he said it wouldn't start my first thought was he seized it due to timing issue. I would have suggested turning the engine over by hand to ensure its clear. But fortunately that wasn't his issue.
-Robert
Old 09-08-2020, 11:59 PM   #37
Tobacconist
Tobacconist is a jewel in the roughTobacconist is a jewel in the roughTobacconist is a jewel in the rough
Did you get this issue resolved?
I am currently having the same issue. I have a feeling it is corrosion or some other issue with the wiring.
Tobacconist is offline   Reply With Quote
Old 09-16-2020, 03:44 PM   #38
Designie
2006 VUE Red Line
Unfortunately, no I never figured it out. It has been sitting since last year. I will start it every once in a while, of course all the while fighting to keep it running until the temp gets up. Then like magic, it runs like a swiss watch! Then I'll take it for a quick spin around the block then park it again until the next time.
I have a code reader and will pull the current codes shortly.
Old 09-16-2020, 04:02 PM   #39
Is your engine a 3.5L V6? If I'm not mistaken, these engines require periodic valve adjustment. Search past threads about poor engine running related to exhaust valves and adjusting them to correct running problems.
Old 09-27-2020, 10:27 PM   #40
Tobacconist
The DTC P0336 document was very helpful for me.
I am getting the following codes.
P0341 Cam position sensor
P0718 Trans input speed sensor
P0386 Crank sensor B
P0336 Crank sensor A
I noticed that on the PCM, the crank A+B, cam and trans input sensors use pins # 20, 21, 22 and 24 on connector C1.
From the DTC document the specified voltage on step #6 for Crank sensor B fluctuates 6-8 volts instead of 5 volts as specified.
I believe there is an internal issue in the PCM so I got a replacement from a junkyard but the car will not start with the replacement. My car is a 2005 and the new one is from a 2006.
Do they require a re-flash?
06 Vue redline K&N cold air intake question 06redline Vue General 8 09-02-2009 06:24 PM
Good cold start, trouble starting when not cold, fast idle 2001 SL2 composerchris Community Center 2 12-05-2008 03:02 AM
Won't idle when cold; hard starting when very cold photoworks S-Series General 5 02-18-2008 01:24 PM
No Fast Idle on Cold Start Up and Strange Idle There After Larry Horne S-Series Tech 11 07-21-2006 03:18 PM
cold starts with redline amishland Ion General 21 10-21-2004 10:06 AM
