Old 07-17-2003, 08:25 PM   #1
tomsw2
tomsw2 is on a distinguished road
Default sw2 rear hatch release
Hi all - first time to post a question, but I've taken advantage of everyone's advice surreptitiously- thanks. I have a 97 SW2 with a balky rear hatch release. When I press the key fob or pull the release in the car, the latch makes a horrible buzzing noise - almost sounds like little gears grinding against one another. The latch opens despite the noise, but obviously something is not right and I would like to fix it before it self-destructs. Is the latch unit on the hatch a sealed unit, or can I take it apart and try my customary poking around to see if I can decipher the problem? Any suggestions will be appreciated
Thanks in advance
Tom
tomsw2 is offline
Old 07-18-2003, 03:04 PM   #2
wolfman
wolfman's Avatar
Default
YES you can take it apart with confidence (not easy to break) Sounds like it just may be in need of some lubrication. Recommend "Spray cable and chain lube" (Walmart) for the mechanism.
wolfman is offline
Old 08-12-2003, 06:35 PM   #3
tomsw2
Default
Wolfman, thanks for the suggestion. After finally getting up enough courage to rip off the plastic covering the rear hatch, I figured out my problem lies in the little module that opens the latch when the remote entry button is pushed. I don't know the name of it, but it is a 2 inch by 5 inch black module with a piston arm out one side that attaches right next to the actual rear latch. I took it apart and a small plastic gear that drives the piston out has lost a couple of teeth (probably a $.10 part). I called saturn to see how much a replacement would be and was told they only sell the whole module for $87. So I called junk yards in the area but have had no luck finding the part. Does anyone know if the same part can be found on other makes/models of cars so that I could get a used or salvage one for less? Thanks for your help
tomsw2 is offline
Old 08-12-2003, 09:35 PM   #4
Default
Try Joey at
Joe Cutrone
sales@6thplanetusedparts.com
for a used one.
ssicarman is offline
Old 08-12-2003, 10:11 PM   #5
ProDarwin
ProDarwin is on a distinguished road
Default
It's a hatch release solenoid. A salvage one is fine.
-Travis
ProDarwin is offline
A few SW2 problems - hatch release, rear wiper d_rock S-Series Tech 22 07-19-2009 12:26 AM
Rear Hatch release OldManRobb 2008 Vue 2 06-11-2008 07:14 PM
Wagon Hatch Release SCMike S-Series Tech 4 08-06-2007 08:56 AM
Rear Hatch Release jocko95 Vue General 30 03-09-2004 09:26 PM
Saturn SW2 Remote Hatch Release Problem kbg1 S-Series Tech 8 07-15-2003 12:21 AM
