Old 04-19-2013, 06:37 AM   #1
silver sl2
silver sl2 is on a distinguished road
2000 SL2
Default Throttle position sensor
Got a 2000 sl2 and and cleaned the TB and put it back on and it wont accelerate properly. there is no vacuum leaks and i think i put the tps on wrong. Is there a certain way to put this back on?
Add to silver sl2's Reputation
Rate the quality of this post and help silver sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
silver sl2 is offline   Reply With Quote
Old 04-19-2013, 08:44 AM   #2
Default Re: Throttle position sensor
Yes, the toung on the throttle shaft is engaged with the TPS and then the TPS is turned slightly in the throttle OPEN rotation direction to slow inserting screws. If you just stuck it on and tightened the screws it is probably now broke.
Old 04-19-2013, 09:55 AM   #3
silver sl2
2000 SL2
Ok so put it on then turn it toward the OPEN position to insert the screws? I didnt know that. So if i put it back on the way you said and there is no difference then it is probably broke?
Old 04-19-2013, 10:13 AM   #4
I would think so.
Old 04-19-2013, 02:05 PM   #5
silver sl2
2000 SL2
Wouldnt the tps make the ses com on if it is bad?
Old 04-19-2013, 02:35 PM   #6
jhonky
jhonky is on a distinguished road
can someone make a video showing the proper way to put it on because i'm lost. i've cleaned my tb twice but just put it on the same way i took it off and put back in the screws
98 SL2
5th gear swap- .643 gear
245,000 miles
215/45 17"
I burn about a quart about every 1500 miles.
If it ain't broke, fix it some more.
Last edited by jhonky; 04-19-2013 at 02:36 PM.. Reason: video would probably only take up 30 minutes of your time
Add to jhonky's Reputation
Rate the quality of this post and help jhonky reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jhonky is offline   Reply With Quote
Old 04-19-2013, 02:57 PM   #7
I'm 99% sure you can't put it on wrong. There's a notch for the throttle plate rod to go into which I guess you could muck up but not if you're paying attention to it.
Video? "Let me Youtube that for you" search term: "Throttle Position Sensor Saturn": http://www.youtube.com/watch?v=Na6Hgu2qwLg
Old 04-19-2013, 03:55 PM   #8
jhonky
oh. i only remove the tps when i remove the entire tb. if you do it that way i don't think you can mess it up
98 SL2
245,000 miles
215/45 17"
Throttle Position Sensor? lgates3522 Vue Tech 26 05-27-2017 03:29 PM
Throttle Position Sensor mommybayer Relay Tech 0 12-11-2009 06:05 PM
Throttle Position Sensor saturncrzy S-Series Tech 6 05-15-2008 06:29 PM
Throttle Position Sensor? thewave46 S-Series General 3 12-11-2007 02:15 PM
Throttle Position Sensor sven1 L-Series General 0 05-31-2006 09:54 AM
