Old 05-15-2008, 11:54 AM   #1
saturncrzy
saturncrzy will become famous soon enough
1992 SL2
Question Throttle Position Sensor
Was just curious if this can be cleaned or jusy buy a new one?
Add to saturncrzy's Reputation
Rate the quality of this post and help saturncrzy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturncrzy is offline   Reply With Quote
Old 05-15-2008, 11:58 AM   #2
Low Saturn
Low Saturn's Avatar
2000 SC2
Default Re: Throttle Position Sensor
They really dont get dirty. Nothing from behind the throttle plate comes in contact with the sensor.
Mike
11.809 @ 116.488 mph
www.differentracing.com
-2000 Saturn SC2
-2001 Chevrolet Suburban
Old 05-15-2008, 12:44 PM   #3
I wonder if something like electronics cleaner would work on it. It's basically a potentiometer -- a variable resistor that varies with the rotation of the throttle plate shaft. It's about like a mechanical volume control on an "old" radio. Remember how volume adjustments would start to sound scratchy when those things got old/dirty? And _sometimes_ a shot of electronics cleaner, followed by turning the knob back and forth to work it in, would clear it up? I wonder if flaky CPS behavior isn't something akin to this, and if it _might_ be improved by shooting some electronics cleaner ("tuner cleaner")into it and rotating the shaft several times.
Add to madpogue's Reputation
Old 05-15-2008, 01:34 PM   #4
waldo_2001
waldo_2001 is on a distinguished road
waldo_2001's Avatar
For what it's worth I replaced mine on my 01 SC2 because I thought the idle was a little high between 900 and 1100 rpm, anyway nothing changed so I have one for cheap if you like. Of course I can't guarantee it is perfect but at leat it's not $50,
James H
Make an offer
2001 SC2, 167,000k
EGR Chk
TPS Chk
ECTS Chk
Throttle Body Cleaned
Injectors Cleaned
PCV Chk
All Tams Replaced
Struts Replaced
Scan Gauge (toy)
With all of that 42mpg!!
Add to waldo_2001's Reputation
Rate the quality of this post and help waldo_2001 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
waldo_2001 is offline   Reply With Quote
Old 05-15-2008, 02:53 PM   #5
Low Saturn
Low Saturn's Avatar
2000 SC2
James H
Make an offer
Just an FYI, your TPS will only work on 2000-2002 DOHC's
Mike
-2000 Saturn SC2
Old 05-15-2008, 03:31 PM   #6
DIYguy
DIYguy's Avatar
Dizzy Re: Throttle Position Sensor
Whatever you do, don't buy a Wells brand replacement. I put one on over a year ago in an attempt to solve an idle problem of my own (since resolved), and a few months later the replacement became the new problem with all the classic symptoms.
Thankfully I still had the original (Saturn OEM) one laying around and so I put it back on. Problem resolved immediately. It is still on the car.
For curiousity's sake I opened up the Wells unit. The way it was built I don't doubt at all why it failed. I should have returned it rather than opening it up, but they just would have given me another one.
FWIW.
Add to DIYguy's Reputation
Rate the quality of this post and help DIYguy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 05-15-2008, 05:29 PM   #7
I tried just that on the TPS on a 90 Chevy G-30 van. It was an exercise in futility. But, if you understand how to check them for noise at the throttle closed position you will find the bad ones real quick.
Throttle Position Sensor mommybayer Relay Tech 0 12-11-2009 05:05 PM
throttle position sensor briansc1 S-Series Tech 7 08-04-2008 05:42 AM
Throttle Position Sensor? thewave46 S-Series General 3 12-11-2007 01:15 PM
testing the throttle position sensor sPuddingTime S-Series General 6 06-07-2006 09:57 AM
Throttle Position Sensor sven1 L-Series General 0 05-31-2006 08:54 AM
