Old 12-11-2007, 10:56 AM   #1
thewave46
thewave46 is on a distinguished road
Default Throttle Position Sensor?
Hello,
I just wanted a little input on this condition before I go throwing parts at it.
Symptoms: Car is fully warmed up. New brass ECTS. Occasionally, without any throttle pressure and clutch out, switches to higher idle and revs slowly climb. Shutting down vehicle and restarting results in normal idling returning. This seems to point to a sensor and not a vacuum leak.
Does this sound right?
Add to thewave46's Reputation
Rate the quality of this post and help thewave46 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
thewave46 is offline   Reply With Quote
Old 12-11-2007, 10:58 AM   #2
thewave46
Default Re: Throttle Position Sensor?
Oh, the car is a 1998 SC1 with 132,000kms on it (82,000mi).
Old 12-11-2007, 10:59 AM   #3
Yes, high idle "reset" on re-start typically means a bad TPS. Another test - when it's racing, tap the TPS with a screwdriver handle. If this changes the idle, TPS is a prime suspect.
Add to madpogue's Reputation
Old 12-11-2007, 01:15 PM   #4
BoDuke70
BoDuke70 is on a distinguished road
BoDuke70's Avatar
2004 ION-3 Quad Coupe
Just another guess, is there a loose vacuum connection - or a break in a hose that's gaping then closing up upon engine shutoff / vibration stop?
A different kind of parts guy...now in a bow tie!
Add to BoDuke70's Reputation
Rate the quality of this post and help BoDuke70 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BoDuke70 is offline   Reply With Quote
Throttle Position Sensor mommybayer Relay Tech 0 12-11-2009 05:05 PM
throttle position sensor briansc1 S-Series Tech 7 08-04-2008 05:42 AM
Throttle Position Sensor saturncrzy S-Series Tech 6 05-15-2008 05:29 PM
testing the throttle position sensor sPuddingTime S-Series General 6 06-07-2006 09:57 AM
Throttle Position Sensor sven1 L-Series General 0 05-31-2006 08:54 AM
