Old 09-20-2018, 04:59 AM   #1
BlueArmz
BlueArmz is on a distinguished road
Happy Correct brake bleeding order
This has probably been brought up before, but just wanted to verify. I've always done furthest from master cylinder to closest. I've also seen a different order for the SL which alternates from back to front, back to front.
Which is correct?
Add to BlueArmz's Reputation
Rate the quality of this post and help BlueArmz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BlueArmz is offline   Reply With Quote
Old 09-20-2018, 06:34 AM   #2
Waiex191
Waiex191's Avatar
Default Re: Correct brake bleeding order
I did mine furthest to nearest when I rebuilt the '99. When I replaced the front lines on the '98 I only bled the fronts.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 09-20-2018, 08:17 AM   #3
There are the brake bleeding pages from the FSM in my photo gallery. It is not as clear as you would think so best to take a look.
Old 09-23-2018, 02:30 AM   #4
Packard
Packard is a jewel in the roughPackard is a jewel in the roughPackard is a jewel in the rough
1995
If working on abs even with light on
I bleed mine this way lights were on and it got my brakes working again
bleed the rear bleed screw nearest the master cylinder and then the front one nearest the front of car. I used a vacumm pump never let it sit below 25 inch mercury when i opened the screws. I just pumped it as I opened cause I had no helper. It worked and Ive passed all my inspections since and light and replaced rear wheel cylinder.
Right Rear and left front same circuit
left rear and right front same circuit
Split diag system
Add to Packard's Reputation
Rate the quality of this post and help Packard reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Packard is offline   Reply With Quote
Old 09-23-2018, 02:57 PM   #5
onlinebiker
It also depends what method you use.
If using a vacuum pump and a separator ( I do) it really doesn't matter.
If by pumping the brake, holding down while a helper opens, then closes the bleeder - you should do front, then opposite side rear. Then other side, same way.
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 09-24-2018, 12:31 PM   #6
Brake fluid bleeding procedures for the majority of dual diagonal brake systems are usually stated in service manuals to bleed from the farthest to closest; left hand drive vehicles with brake master cylinder on the driver's side - right rear and left front, left rear and right front.
The explanation for specific bleeding sequence is to move any air in a line that's farthest away from the master cylinder first. In most cases, this is the right rear. Once the farthest line (r/r) is bled, the left front is bled since these two lines are connected as one half of a dual diagonal line. The left rear is bled then right front.
In theory, bleeding the two rear brakes first then both front appears to be fine with no one reporting issues but following service manual procedures is best.
Which is the Correct Brake Bleeding Sequence ???? tgparker S-Series General 3 12-19-2014 03:05 AM
Spark wires to ignition correct order davidt321 S-Series General 28 12-10-2011 08:34 PM
brake bleeding help detroitindustri S-Series Tech 9 08-06-2008 11:52 AM
ABS & brake bleeding Hipster S-Series Tech 17 09-06-2007 02:04 PM
Correct Order? adamv3 Mods and Performance 10 04-05-2005 03:37 PM
