Old 09-04-2018, 06:47 PM   #1
cuetip
cuetip is just really nicecuetip is just really nicecuetip is just really nicecuetip is just really nicecuetip is just really nice
1997 SW1
Dizzy Valve Body Mystery Connector Leak
About a year ago I had a reputable transmission shop replace the valve body on my '97 SW1 because it started leaking from the electrical connector area. Ever since then it keeps leaking from there. My transmission shop has tried replacing the seal, using RTV around the seal, thread sealant in the connector bolt hole... I'm going to be taking my car back to them again next week because it's leaking again. Any idea what could be causing this? Is there anything else they can try?
Add to cuetip's Reputation
Rate the quality of this post and help cuetip reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cuetip is offline   Reply With Quote
Old 09-05-2018, 01:57 PM   #2
cuetip
1997 SW1
Default Re: Valve Body Mystery Connector Leak
Anyone?
Old 09-05-2018, 04:11 PM   #3
jpsuli
jpsuli is on a distinguished road
jpsuli's Avatar
Hows the transmission fluid level? Where is it leaking from the connector?
Personally, I'd rip a connector off of an old saturn along with the Valve body metal cover. That connector on my car has been on and off numerous times without a leak
Tho, there are better members to answer this question
'97 Saturn SL2 @ 134k
Breakin' stuff as we go.
Add to jpsuli's Reputation
Rate the quality of this post and help jpsuli reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jpsuli is offline   Reply With Quote
Old 09-05-2018, 07:25 PM   #4
Is the xmission vent plugged, preventing normal venting when oil heats up and cools down?
Old 09-05-2018, 11:25 PM   #5
cuetip
1997 SW1
Where would the vent be located and how can I check it?
Old 09-06-2018, 10:54 AM   #6
The auto's don't have a vent.
Fluid level should be in the "ok" range, not to the top of the 'full'.
Old 09-06-2018, 12:12 PM   #7
That's interesting. I assumed the S-series autos have a xmission vent tube like I have on my L300 auto. If the S-series autos are sealed without a vent, this may explain why oil is 'venting' thru the electrical cover.
Old 09-06-2018, 01:20 PM   #8
cuetip
1997 SW1
Fluid level was always correct when the leak happened. It was bone dry up until a few years ago. Now it won't stop leaking. There has to be a reason
Old 09-06-2018, 02:42 PM   #9
Cheyne
2000 SL2
You could try to replace the seal again:
https://www.ebay.com/itm/Saturn-TAAT...gAAOSwNSxVP76f
If a new seal doesn't do it, then the cover may have been damaged.
Add to Cheyne's Reputation
Old 09-06-2018, 03:23 PM   #10
cuetip
1997 SW1
Thanks for the link! My mechanic said he replaced the seal. I've taken the cover off before when I tried replacing the seal before I took it to the shop. It didn't appear to be damaged. The underside was in immaculate condition. Could it have warped?
Old 09-06-2018, 03:28 PM   #11
TomM96
Cuetip--
What type ATF are you running?
When i used the Valvoline Red (which Lower Viscosity than OEM), my connector weeped a little. OldNuc advises that thinner fluid runs hotter...
After switching to the Valvoline Blue (which very close to OEM viscosity), the shifts were cleaner (more pressure) and the weeping from the connector ceased.
I think the option of using another cover-with-connector from a wrecking yard is promising. I also think new connectors may be available from PartsGeek or RockAuto....
Add to TomM96's Reputation
TomM96 is online now   Reply With Quote
Old 09-06-2018, 09:31 PM   #12
cuetip
1997 SW1
Originally Posted by TomM96 View Post
Cuetip--
Fascinating... I've been using Amsoil ATF for longer than I can remember: https://www.amsoil.com/shop/by-produ...mission-fluid/
Is this no good for our cars?
Old 09-06-2018, 10:00 PM   #13
Cheyne
2000 SL2
The Amsoil is fine. cSt 7.5 @ 100C
Old 09-06-2018, 11:37 PM   #14
cuetip
1997 SW1
Hmm. What next? Are there any TSBs for this issue?
Old 09-07-2018, 08:42 PM   #15
Cheyne
2000 SL2
Is the leak coming from inside the connector/buss plate or from between the cover and seal?
Old 09-08-2018, 02:27 AM   #16
cuetip
1997 SW1
It's hard to tell. There's fluid in both areas. The foam seal around the connector is soaked in fluid. I wonder if the Amsoil ATF is to blame...
Old 09-08-2018, 10:38 AM   #17
Cheyne
2000 SL2
The problem is still most likely the seal linked above.
You could always PM Special Forces or call Ken Partin for another opinion and the part.
https://www.ebay.com/itm/SATURN-SL1-...VRQ1A2&vxp=mtr
Old 09-08-2018, 01:58 PM   #18
cuetip
1997 SW1
Thanks for the link but I'm at the mercy of the transmission shop's discretion for parts. I paid them $1000 to do it (they also did a flush and external filter change too) and it's still under warranty.
Come to think of it, the leak didn't start until after I started using Amsoil ATF. It wasn't immediate though.
Old 09-08-2018, 02:07 PM   #19
Cheyne
2000 SL2
The shop filled with Amsoil also?
Old 09-08-2018, 04:37 PM   #20
cuetip
1997 SW1
Yes. I supplied them with correct amount for the job they were doing.
I PMed special forces. We're discussing it now. Any input is still appreciated 🙂
Valve body connector 7mm bolt is spinning in place Jonasan308 S-Series Tech 14 08-16-2017 05:11 PM
transmission valve body connector test lancer54 S-Series General 9 12-14-2015 12:00 PM
Fluid in electrical connector top of valve body dcmille290 S-Series Tech 0 05-30-2015 03:16 PM
Valve Body electrical connector Michael2453 Community Center 0 02-26-2014 05:03 PM
Valve Body Electrical connector mehalski S-Series Tech 2 08-06-2007 12:06 PM
