Old 06-21-2018, 10:19 AM   #1241
Default Re: how many miles do you have on your saturn?
Wow, that car looks amazing, esp considering the miles.
How often did you change the oil?
Hard to argue with success, but the PL20195 also fits and gives you a little more capacity. It's almost 1 1/2" longer, spec comparison here
https://www.bobistheoilguy.com/forum...95_vs._PL10241
(I think the fact you are using DexCool and have been for 400k miles is going to blow Saturn Night's gasket - expect a demand for video)
Old 07-02-2018, 08:53 PM   #1242
ivan0_10
ivan0_10 is on a distinguished road
2001 SL1 218K miles
Add to ivan0_10's Reputation
Rate the quality of this post and help ivan0_10 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ivan0_10 is offline   Reply With Quote
Old 07-03-2018, 11:55 AM   #1243
Eienring
Eienring is on a distinguished road
My 2001 SC1 is at around 92K, was about 45K when I bought it back in 2004. Tells you how little I drive.
Add to Eienring's Reputation
Rate the quality of this post and help Eienring reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Eienring is offline   Reply With Quote
Old 09-24-2018, 03:54 PM   #1244
cwalden
cwalden is on a distinguished road
1999 SL1
My mother recently passed away and she had a 1999 Saturn SL1. It was given to me. Much to my surprise it only has 80,617 miles on it.
Add to cwalden's Reputation
Rate the quality of this post and help cwalden reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cwalden is offline   Reply With Quote
Old 09-24-2018, 05:11 PM   #1245
SRGW
SRGW is a glorious beacon of lightSRGW is a glorious beacon of lightSRGW is a glorious beacon of lightSRGW is a glorious beacon of lightSRGW is a glorious beacon of lightSRGW is a glorious beacon of light
1997 SL1
Post Re: how many miles do you have on your saturn?
Only 67,500 on my 1997 SL1.
1995 SL1 236,300 2005>2018
1997 SL1 67,500 21 yrs. and Legal!!
CHECK YOUR OIL!!
Add to SRGW's Reputation
Rate the quality of this post and help SRGW reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 09-24-2018, 07:45 PM   #1246
gveinot
gveinot is just really nicegveinot is just really nicegveinot is just really nicegveinot is just really nice
gveinot's Avatar
2000 SL2
2000 SL2
2000 Saturn SL2, I'm up to 450,600km. Owned the car since new, always on Synthetic. Oil changed every 6000 - 8000 km. Uses about 2L per OCI. Original engine, alternator, power steering pump, starter, fuel pump, transmission ( except for valve body ) rack pinion, coil packs. Items replaced other than brakes, suspension, and exhaust is: valve body, blower motor, radiator, driver inside door lock button, dash lamps, EGR, TPS, IAC, ECT Sensor, idler pulley, belt tensioner, one low beam bulb, and all wheel bearings. Of the valve body, I replaced the TCC Solenoid and Line Pressure Solenoid in the changed valve bodies. We live in Nova Scotia, rust capital of Canada. This one is heavily undercoated every year and spot undercoated every oil change. The drivers seat has a busted spring that popped a hole in the back of the seat. The bulbs all blew in the radio except one. The engine runs very quiet, listening to it you would never know it is at this mileage and age.
Add to gveinot's Reputation
Rate the quality of this post and help gveinot reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gveinot is offline   Reply With Quote
Old 10-16-2018, 11:00 AM   #1247
TheNoteTaker
TheNoteTaker is a jewel in the roughTheNoteTaker is a jewel in the roughTheNoteTaker is a jewel in the rough
1996 SC2 with 153k on the body and trans, just rebuilt the dual cam in it.
1996 SC2 1.9L DOHC w/auto trans. and only 136K original....It's purple :3
Add to TheNoteTaker's Reputation
Rate the quality of this post and help TheNoteTaker reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TheNoteTaker is offline   Reply With Quote
Old 10-16-2018, 02:09 PM   #1248
Reliabilityman
Reliabilityman is on a distinguished road
Reliabilityman's Avatar
356,000 miles, original clutch and back brakes. Clear coat is starting to peel after being in a hail storm.
1995 Saturn SL1 Owned since new
356,000 Miles Original Clutch, Back Brakes
2000 L Series Owned since new
153,000 Miles, Melted Fuse Box, Randomly Opening Trunk, Leaking AC condensate into cabin,
Add to Reliabilityman's Reputation
Rate the quality of this post and help Reliabilityman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Reliabilityman is offline   Reply With Quote
Old 03-19-2019, 07:15 AM   #1249
tomaso401
tomaso401 is on a distinguished road
2003 Vue 2.2 with 5 speed. Currently at 350k miles. Working to beat those pesky 400K guys.
2003 Saturn Vue 2.2
316,000+miles
She won't die...
Add to tomaso401's Reputation
Rate the quality of this post and help tomaso401 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tomaso401 is offline   Reply With Quote
Most miles on a Saturn SaturnManiac General Saturn Discussion 72 04-01-2018 01:49 AM
'02 SL, 104,xxx miles, going through 1qt/250 miles, 20 MPG!!! jeadra S-Series General 10 12-12-2009 05:48 PM
How many miles are on your Saturn? Arnel General Saturn Discussion 72 07-08-2003 12:55 AM
Like New 16" Chrome-Clad L-Series Wheels (4,500 miles) with tires (250 miles) UH2L Classifieds 6 07-07-2003 03:34 PM
How Many Miles on Your Saturn? ProjectSW1 General Saturn Discussion 53 06-12-2001 06:37 PM
