Old 03-25-2008, 12:59 PM   #21
angelaw
angelaw is on a distinguished road
angelaw's Avatar
1996 SL1
Default Re: how many miles do you have on your saturn?
Honestly have no clue. Bought car, supposedly had 121k. Year before when it was registered it has 119k thru DMV. Engine had 45k-49k miles on it (that I verified). Cluster had been swapped to a DOHC so I have no idea, but figure at least 150k miles now. I replaced cluster with a sohc that had 84k miles on it, so if I add the difference, around 150k now. Engine has about 75k on it.
Needless to say it's mileage exempt.
Add to angelaw's Reputation
Rate the quality of this post and help angelaw reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
angelaw is offline   Reply With Quote
Old 03-25-2008, 01:29 PM   #22
gordoloff
gordoloff is on a distinguished road
gordoloff's Avatar
I have 192,000 miles on mine, all original.
1995 Saturn SL1 Sohc 311,000kms
Add to gordoloff's Reputation
Rate the quality of this post and help gordoloff reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gordoloff is offline   Reply With Quote
Old 03-25-2008, 02:34 PM   #23
dave.sl
dave.sl has a spectacular aura aboutdave.sl has a spectacular aura about
98SL 157k. Original engine,trans,clutch. 1quart of dino 5W-30 every 4000-4500 miles. 36-41MPG. Other than a couple of sensors, tensioner, right front axle, instrument cluster,maintenance items etc., everything is original. I also run 1 pint of MMO in crankcase and 4 ounces in the gas tank at fillup. Ran mobil 1 for the first 100k or so. Don't know if that is the reason for longevity so far, but it sure didn't hurt. My theory is if you never let them run low on oil or overheat the motor, they will not turn into oil burners! I am sure there are exceptions.
Add to dave.sl's Reputation
Rate the quality of this post and help dave.sl reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dave.sl is offline   Reply With Quote
Old 03-25-2008, 03:37 PM   #24
phurkee
phurkee is on a distinguished road
282,000 1996 Sl
Add to phurkee's Reputation
Rate the quality of this post and help phurkee reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
phurkee is offline   Reply With Quote
Old 03-25-2008, 04:39 PM   #25
lascrew
lascrew is on a distinguished road
lascrew's Avatar
1997 SL
132K; original.
'97 SL
Add to lascrew's Reputation
Rate the quality of this post and help lascrew reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lascrew is offline   Reply With Quote
Old 03-25-2008, 05:10 PM   #26
fujioko
fujioko is on a distinguished road
fujioko's Avatar
1996 SW1
My SW1 ran for 236,000 before the engine suddenly started burning massive amounts of oil. (5W-30). Original engine and clutch… also original ECTS!
I abused the car for many years by running it 10K between oil changes and pulling a trailer weekly.
As soon as it gets a little warmer here in Mi, I’ll pull the engine and investigate problem. I want to run the car for another 250K miles before I give up.
96 SW1 5spd & trailer hitch 309000 miles <--rebuilt!
79 Triumph Spitfire <--British car
94 Mazda Miata 45MPG
91 Mazda Miata 3 cyl. 51MPG
Add to fujioko's Reputation
Rate the quality of this post and help fujioko reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
fujioko is offline   Reply With Quote
Old 03-25-2008, 05:28 PM   #27
Keviefriend
Keviefriend is on a distinguished road
My 95 SL1 has 197,285 miles and will turn over 200,000 sometime in May (I drive minimum of 45 miles/day if I only go to work and home again, so by that logic it'll be 60 days, but I'm probably going to Duluth on Friday so that'll be aboot a week's worth right there). I will drive it to literal death, I love my little car and I get better mileage than anyone I know except the one friend of my mom's who has a prius (Christ, I really hope her batteries don't ever die. They cost a fortune to replace and the car won't go around the block without them...)
Kev
98 SL2M red loaded+working sunroof 135K miles sold 2011
95 SL1M teal totalled November 08.
99 Yahama Razz scooter
Looking for another under $1k in or somewhat near Minneapolis
Add to Keviefriend's Reputation
Rate the quality of this post and help Keviefriend reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Keviefriend is offline   Reply With Quote
Old 03-25-2008, 06:59 PM   #28
Zvolen
Zvolen is on a distinguished road
1998 SL1
Just rolled over 125K on my 1998 SL, all original and doesn't really burn any oil :Crosses Fingers:
1998 SL Bought in Nov 06' w/ 115K 22MPG, Currently 165k 30MPG (city)
Add to Zvolen's Reputation
Rate the quality of this post and help Zvolen reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Zvolen is offline   Reply With Quote
Old 03-25-2008, 07:17 PM   #29
Niteshooter
Niteshooter is on a distinguished road
Niteshooter's Avatar
2000 SL2
1999 SL1
We have three all over 100,000km.
99 SL1 200,890 km having emissions problems. Blown engine at 150,000 replaced with wrecker motor with lower km. Clutch at 160,000. Uses 1 L of oil every 2000 km. bought new. Bought used w/100,000 km.
99 SL2 187,000 km uses 1 L of oil every 1500-2000 km due for clutch soon.
00 SL2 191,000 km had head gasket done under warranty. Burns 1 L every 5000 km. Original battery finally failed yesterday.... bought new.
Kevin
www.kevinomura.com/saturns our Saturn family.
Add to Niteshooter's Reputation
Rate the quality of this post and help Niteshooter reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Niteshooter is offline   Reply With Quote
Old 03-26-2008, 03:25 AM   #30
The Critic
The Critic is on a distinguished road
The Critic's Avatar
96 SL2, 112,000 miles. 2/3 qt/3000 miles oil consumption.
'10 Altima 3.5SR V6- 5k
'96 SL2- 150k!
'92 Previa- 99k
Add to The Critic's Reputation
Rate the quality of this post and help The Critic reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
The Critic is offline   Reply With Quote
Old 03-26-2008, 08:51 PM   #31
purepwrSL2
purepwrSL2 is on a distinguished road
purepwrSL2's Avatar
a mere 66k on my '94 SL2 1 and 1/4 qts oil used @ 3,000 miles dino oil,,, Syn oil use less oil hasn't keep track on this ones. Just one tire and one back-up light switch, one battery replaced so far. the rest are all maintenece as usally . will be 15 years ownership this Fall .
Add to purepwrSL2's Reputation
Rate the quality of this post and help purepwrSL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
purepwrSL2 is offline   Reply With Quote
Old 03-26-2008, 11:38 PM   #32
redkees@msn.com
redkees@msn.com is on a distinguished road
redkees@msn.com's Avatar
2004 VUE 2.2L
2008 AURA XE
My 98 SL2 has 215,000 miles on it. Runs well. Since I bought my Vue it now gets some rest. Now I drive it a couple of days a week to give it some light exercise.
Burns very little oil, in fact since I replaced the cam cover gasket I'm not losing any oil now. Yes I change the oil every 3,000 miles and check it regularly.
Previously Owned 98 SL2, Sold
98 SL, Sold
When your Saturn is well kept YOU are well kept.
Second Car: Buick LaCrosse 2006
Add to redkees@msn.com's Reputation
Rate the quality of this post and help redkees@msn.com reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
redkees@msn.com is offline   Reply With Quote
Old 03-27-2008, 01:57 AM   #33
mjo
mjo is on a distinguished road
mjo's Avatar
'95 SL2 with 175k miles and newer engine and transmission. The engine was replaced @ 100k miles due to low oil. Transmission was replaced @ 160k Miles due to a succession of accidents with the transmission cover.
Mods to this car: Bypass filters on transmission and engine, external cooler for transmission, HAI and PCV catch can. Hoping to put another 200k miles without a major auto accident.
'92 SL1 bought @ 207k now with 209k miles and supposedly with the original engine and transmission but the engine leaks a bunch of oil.
Car has 2,000,000 mm and runs like new!
Add to mjo's Reputation
Rate the quality of this post and help mjo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mjo is offline   Reply With Quote
Old 03-27-2008, 03:26 AM   #34
JADEDSL2
JADEDSL2 will become famous soon enough
JADEDSL2's Avatar
Location: Sullivan, Missouri, USA, North America, Northern West Hemisphere, Earth, Solar System, Left Galactic Arm, Milky Way Galaxy, Local Galactic Cluster, Universe
1993 SL2
1991 SL2
Lol, well, most people know about Trinity, my little frankenstein 93 SL. The powertrain is from a 99 SC2m, and, oddly enough, is within 3/10 of a mile of the actual original mileage on the body, so I count them together. Anyway, 99 DOHC, original, 155,799 as of this evening. I burn about 1/4 quart a day, (100 miles or so). It guzzles it, but hey, it's running fine, and at 37.5 mpg's, I'm not worried about buying more oil all the time, for now. Next spring I am planning on grabbing a Jasper .020 overbore long block to replace the quickly aging engine I'm using now. For some reason (cough, lead foot, cough), engines don't last long around me, even though I routinely maintain them. Sure, I could get 300K out of it, but I'd rather not. It's time for a fresh new start for my Saturn. All in all though, I'm still happy with it. Needs more power, and I have neither the time nor money (3 kids) to do it, so it'll have to wait. But I've got a 95 lower front fascia, and a DOHC rear swaybar setup waiting to be put on, both of which I got for free (thanks Matt), so it's a work in progress, as it will probably be for the rest of my life. Never thought I'd be keeping an old 1st Gen base model alive as long as I have. Life is full of surprises, and until I an afford the NEXT generation Astra, hopefully with the 2.0L turbo engine this time, I won't be buying anything new. God I'm such a cheapskate. Typical Saturn owner.
"1G8ZJ5472MZ134321"-my Jaded, I will never forget.
"1G8ZF5594PZ249184"-Trinity, for three are now one.
Add to JADEDSL2's Reputation
Rate the quality of this post and help JADEDSL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JADEDSL2 is offline   Reply With Quote
Old 03-27-2008, 06:10 AM   #35
kay
kay is on a distinguished road
I've got a 1993 SL2 that is approaching 125,000 miles. Does anyone know what the typical lifespan is for an SL in terms of years/miles? Looks like I am on the low side for mileage compared to others here, but 15 years seems like a pretty respectable age!
Add to kay's Reputation
Rate the quality of this post and help kay reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kay is offline   Reply With Quote
Old 03-27-2008, 03:06 PM   #36
fib4
fib4 is on a distinguished road
1999 sl2 276,000
1997 sl2 255,000
Add to fib4's Reputation
Rate the quality of this post and help fib4 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
fib4 is offline   Reply With Quote
Old 03-27-2008, 06:51 PM   #37
auger
auger is on a distinguished road
'92 SL1, bought new
Answer: 270 000 km = 167.770 mi.
OR 167 mi. and 1355.590 yrd
Heck, it seems like more in kilometers, if I can get this lumpy idle/running figured out I think I can get the little bugger round the clock again.
Had a headgasket done nine years ago, had to replace the intake gasket three years ago or so, two starters, driver's seat back frame, two driver's door window regulators, ECTS three years ago, purge solenoid for the charcoal system, tie rod ends a few years ago.......other than that, tires and plugs and wires and brakes......easiest car on the wallet I ever owned, and it still looks good.
Add to auger's Reputation
Rate the quality of this post and help auger reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
auger is offline   Reply With Quote
Old 03-27-2008, 08:01 PM   #38
Bill Murray
Bill Murray will become famous soon enough
1997 SC1
1997 SC1
130,000 miles on our 97 SC1 bought new in late 96.
Car still looks great despite spending its life in high school & college dorm parking lots.
The engine cradle is showing some corrosion on the driver's side (no oil leaks over there ) but I'm expecting at least 10 more years service.
Add to Bill Murray's Reputation
Rate the quality of this post and help Bill Murray reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 03-27-2008, 08:03 PM   #39
woonyboi02895
woonyboi02895 is on a distinguished road
woonyboi02895's Avatar
191,781k on my 97 sl2 currently running auto-rx and will see how it goes
Add to woonyboi02895's Reputation
Rate the quality of this post and help woonyboi02895 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
woonyboi02895 is offline   Reply With Quote
Old 03-27-2008, 08:50 PM   #40
zombierepellent
zombierepellent is on a distinguished road
95 SL2 186k and 600 some odd miles. Too lazy to go out to the car and look
It's not custom if the check engine light isn't on.
Add to zombierepellent's Reputation
Rate the quality of this post and help zombierepellent reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
zombierepellent is offline   Reply With Quote
Most miles on a Saturn SaturnManiac General Saturn Discussion 72 04-01-2018 01:49 AM
'02 SL, 104,xxx miles, going through 1qt/250 miles, 20 MPG!!! jeadra S-Series General 10 12-12-2009 05:48 PM
How many miles are on your Saturn? Arnel General Saturn Discussion 72 07-08-2003 12:55 AM
Like New 16" Chrome-Clad L-Series Wheels (4,500 miles) with tires (250 miles) UH2L Classifieds 6 07-07-2003 03:34 PM
How Many Miles on Your Saturn? ProjectSW1 General Saturn Discussion 53 06-12-2001 06:37 PM
