Old 05-09-2017, 05:00 PM   #1
hoosierrun
hoosierrun is just really nicehoosierrun is just really nicehoosierrun is just really nicehoosierrun is just really nice
2006 VUE 2.2L
Default Just replaced intake manifold on 06 Vue, 2.2
After fighting erratic idle, occasional limp mode, MAP sensor code, and finding no vacuum leaks, I just replaced the intake manifold with a new AC Delco piece.
I tried for a month or so to figure this out, constantly checking for vacuum leaks, substituting a different MAP sensor, replacing throttle body gasket, etc.
Finally with the engine running erratically in the driveway, I sprayed parts cleaner all over the manifold and noticed a change in the idle speed and saw the erratic condition smooth out for a brief moment.
I thought I would just take the manifold off and replace the gaskets, but the plastic manifold worried me. I looked on Amazon and read all the reviews for the AC Delco intake manifold and saw that it resolved a lot of owners problems. I also read that the new manifold comes with all new gaskets. Amazon's price was about $80, but I ended up getting it for $70 from Jet with a 15% discount, no free returns, and pay by debit card. The piece arrived late this morning by Fed Ex and to my surprise, it not only came with new gaskets, but there was a brand new MAP sensor installed in it. This is definitely a good deal.
Changing the manifold was a PITA because of tight conditions. The dipstick tube and several wiring harness barb clips are stuck on it. I had to remove the oil filter housing lid and a stud on the right which is a fastener for the manifold (took a small E-type socket to get it out). The power brake booster and purge vacuum lines had to be unclipped, MAP sensor and TB electrical plugs removed. Then I could wiggle the old unit out and new unit in.
Bottom line is that my problems are resolved. It took a couple of drive cycles for the computer to re-learn the mixture, but I am amazed how well this thing runs (better than when I bought it a couple of years ago).
One additional side benefit is that I know for sure my PCV orifice is fully open. I am always happy when things work out.
Life is good!!
John.... 2006 Saturn Vue, 2.2, 186,000 miles Recently junked out - (threw a rod)
Add to hoosierrun's Reputation
Rate the quality of this post and help hoosierrun reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hoosierrun is offline   Reply With Quote
Old 05-09-2017, 05:59 PM   #2
Default Re: Just replaced intake manifold on 06 Vue, 2.2
Did you find the source of the vacuum leak with the intake manifold removed?
Old 05-09-2017, 06:39 PM   #3
hoosierrun
2006 VUE 2.2L
It was probably the seals. These were changed out 2 years ago with Ebay gaskets when I did the HG. I did notice that PCV orifice was totally carboned over and that there was some oil in the intake manifold internals.
I may have been able to get by with just changing the gaskets, but had it been a hairline crack or warpage, I would have been doing the job again and still buying a new piece. I really just wanted to get the job done quickly and be on my way. $70 is not too bad to spend, considering that I could have suffered all the inconvenience and cost of taking it to a shop.
Replaced Intake Manifold Gasket... (Pic) Pitcher S-Series Tech 0 10-31-2010 07:49 AM
intake manifold TParrish89 S-Series General 3 03-12-2010 10:25 AM
Help! Replaced o2 sensor on the manifold Ikiris S-Series Tech 20 02-07-2010 10:17 PM
Replaced Intake Manifold Gasket 2003ace S-Series General 3 07-25-2006 09:59 PM
WTB: 2000-2002 OE air intake and intake manifold Tycho Classifieds 0 03-03-2005 12:52 PM
