Old 04-26-2017, 12:12 AM   #1
Rockylee80
Rockylee80 is on a distinguished road
Default Sl2 dies when coming to a stop then when started idles high?
My daughter has a 2001 Saturn SL2 165,000 miles. A couple times a week the car will die when coming to a stop. Then when it's restarted it will idle high maybe 2,500-3,000 rpms. I've replaced the CPS, ECTS, cleaned the intake throttle body, removed and cleaned the EGR valve, removed and cleaned the small tube that bolts onto the exhaust manifold (plugged). I'm stumped, maybe the throttle position sensor?
Add to Rockylee80's Reputation
Rate the quality of this post and help Rockylee80 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Rockylee80 is offline   Reply With Quote
Old 04-26-2017, 01:12 AM   #2
Default Re: Sl2 dies when coming to a stop then when started idles high?
You've done most things as a matter of basic maintenance with none of the parts causing this problem (cps, ects and egr valve cleaning). What may be causing high idling is the idle air control valve on the throttle body. The tps is the other electrical part on throttle bodies and most likely not the problem.
The iacv is a slave to the pcm and controls the supplemental air passing thru the iacv. It sets all idle speeds - cold engine startup, warm engine and ac use. The fixed throttle setting of the throttle plate sets a low idle of 500-600 rpm with the bypass air port blocked. The bypass air port allows additional air to raise idle to 750-900 rpm for electronic idle speed control. The iacv uses two stepper motors and if its pintle valve sticks from dirt, exhaust gases, fuel and oil, it can create unusual idle speeds with no rhyme or reason. Either remove it to clean the pintle valve shaft without allowing solvent to seep into the body and try it again or test it. Testing requires a normal idle (800-900 rpm).
If you can test the iacv with a normal idle, remove the air cleaner for access to the throttle body. With engine at normal idle, use a finger to block the little port in front of the throttle plate. The engine should drop down to a low idle, not stall. At this point the pcm detects the low idle and retracts the iacv to allow more air thru the bypass air port you blocked with your finger. Removing your finger should result in an immediate jump in idle as air suddenly flows thru the bypass air port. And immediately after the jump in rpm the pcm detects the higher idle and extends the iacv to return to normal idle rpm. The action of observing the low idle to high then return to normal idle verifies the iacv is retracting and extending from pcm commands as the pcm detects deliberate blocking of the bypass air port.
Old 04-26-2017, 03:26 PM   #3
Jonasan308
Jonasan308 is a glorious beacon of lightJonasan308 is a glorious beacon of lightJonasan308 is a glorious beacon of lightJonasan308 is a glorious beacon of lightJonasan308 is a glorious beacon of light
Jonasan308's Avatar
1999 SC1
So is the air cleaner the thing that attaches on top of the throttle body and has 2 holes leading into the tb? Or does this test require removing the air intake hose?
If its true that blocking it off shouldnt cause a complete stall, i may have a problem. If i put my finger over those holes, my engine will shut off.
1999 Saturn SL1-129k at purchase(may 2016)-139k when wrecked(September 2016)
1999 Saturn SC1(CURSED)-156K at purchase(october 2016)-194k currently (Nov 2018)
Dodging potholes should be a sport
Add to Jonasan308's Reputation
Rate the quality of this post and help Jonasan308 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jonasan308 is offline   Reply With Quote
Old 04-26-2017, 07:47 PM   #4
Jonasan308
Jonasan308's Avatar
1999 SC1
Looks like this?
Old 04-27-2017, 07:58 AM   #5
hoosierrun
hoosierrun is just really nicehoosierrun is just really nicehoosierrun is just really nicehoosierrun is just really nice
2006 VUE 2.2L
Sometimes a vacuum leak at the intake manifold gaskets can cause erratic idle. If it idles rough in your driveway, you can try spritzing a water spray at the intake manifold where it connects to the head area. If you notice a change in engine speed, you identified a vacuum leak.
I have done this with brake cleaner (easier) instead of water, but be cautious if you try it.
John.... 2006 Saturn Vue, 2.2, 186,000 miles Recently junked out - (threw a rod)
Add to hoosierrun's Reputation
Rate the quality of this post and help hoosierrun reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hoosierrun is offline   Reply With Quote
Old 04-27-2017, 11:27 AM   #6
Your picture is showing the vacuum ports of the throttle body, not the bypass air port inside the throttle bore in front of the throttle plate. The first picture in this link shows the bypass port and descriptions; http://mopedalife.tumblr.com/post/20...-body-clean-up
Old 04-27-2017, 12:49 PM   #7
toggenburg
toggenburg's Avatar
1+ on posting that link.
Occasional Intermittent High Idle When Slowing Down or Coming to a Stop raffy S-Series Tech 10 12-01-2014 12:41 PM
93 Saturn sl2 idles high and dies dakota1820 S-Series Tech 4 11-26-2014 12:30 PM
High idle when started, then dies after a few minutes kevinmc58 S-Series Tech 1 05-18-2011 05:58 PM
98 SC2 idles funny, dies, oil in spark plug well, fixed that, still dies, etc. Kpendrgn S-Series Tech 18 02-03-2007 10:58 PM
01 SC2 dies when coming to a stop. Phrosty3 S-Series Tech 6 01-30-2007 09:00 AM
