Old 02-09-2008, 08:05 PM   #1
HDR
HDR is on a distinguished road
1998 SL1
Default 1998 SL1 won't start cold
My wife's 1998 SL1 wouldn't start a few days ago. No spark. Trouble Code P0336 (CPSA circuit range performance). When removed and tested, the CPS showed an open circuit. After I installed a new CPS (measured resistance 748ohms), the car started right away, so I ran it 15 minutes and turned it off. Next morning it cranked fine but fired only occassionally, finally catching and limping up to full run. After warmup, I went for a 10-minute test drive. It ran great--smooth and peppy. I cleared the code and test drove again for 10 minutes. No new codes. Next morning it cranked fine again, firing intermittently, but wouldn't start. (It's cold here--about -25C; the car's in an unheated garage.) The fuel pump whirs when ignition is switched on, and it sounds like it's pressuring up. I'd like to recheck CPS resistance from the engine compartment, but my Haynes manual shows purple and yellow wires from CPS at ignition block connector. Colors are different on this car. Does anyone have any suggestions?
Add to HDR's Reputation
Rate the quality of this post and help HDR reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
HDR is offline   Reply With Quote
Old 02-09-2008, 08:13 PM   #2
Default Re: 1998 SL1 won't start cold
You did a great job troubleshooting the cps as the cause of a no-start problem but may not have followed up further on some other parts that may have fouled. The spark plugs. Remove them for inspection. And did you check to see if you're another victim of the infamous engine coolant temperature sensor (ECTS) failure, making for too rich a fuel mixture? Look in the How-to-Tips first two posts covering the sensor and two-wire connector, pictures and procedures included.
Old 02-09-2008, 09:18 PM   #3
nivlem7
nivlem7 is on a distinguished road
Reminder; '01's have the new brass coolant sensors
Actually, my '01 SL1 had the resin tipped one. I believe mine was an early one, though. I didn't buy it new, so I suppose it's possible that it originally had a brass sensor that was pulled and replaced with a resin tipped sensor, but I highly doubt it.
To the OP, I don't know if it'll help, but I always start mine by doing the following procedure, otherwise, it has difficulty starting.
Turn key to "on" - listen for fuel pump
wait until fuel pump stops, then turn key to "start"
I usually wait a split second after the pump stops before turning to start
maybe a quick light pump on the gas, as it turns over
Add to nivlem7's Reputation
Rate the quality of this post and help nivlem7 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
nivlem7 is offline   Reply With Quote
Old 02-10-2008, 04:53 PM   #4
HDR
1998 SL1
Thanks for your quick response. I will check the plugs and recheck for spark before trying anything else. The temperature gauge seemed to be working correctly on my test drives the other day, so I think that would suggest proper functioning of the ECTS, but I can check it as well if the other approach is unsuccessful. I'll let you know the results. HDR
Old 02-10-2008, 08:21 PM   #5
BarnOwl
BarnOwl's Avatar
Replace the ECTS. The top one in the pic below came out of a '98. If it hasn't happened to yours yet, it will.
Add to BarnOwl's Reputation
Old 02-13-2008, 06:15 PM   #6
HDR
1998 SL1
Update: I checked and cleaned the plugs as suggested (they were a little dirty but not bad). The engine cranked a long time but finally started. I then put a battery charger on overnight, and the car started immediately the next day. Aha, I thought--the battery was just low. The following morning, it was very hard to start again. It finally caught when I stepped hard on the gas. To me this suggested a mixture problem--possibly stemming back to a faulty ECTS. But the Check Engine light came on. New Code PO336 (CPS A Circuit Range/Performance). I just replaced the CPS three days ago. I'm mystified here. Any more suggestions? -- HDR
Old 02-13-2008, 06:40 PM   #7
You must replace the coolant sensor as suggested despite the readings on the gauge. The faulty sensor is incorrectly sending the wrong signal level that's intepreted as richening the fuel mixture excessively as you countered by flooring the gas pedal and allowing more air to dilute the flooded engine enabling a start. The engine in the cold with the original coolant sensor floods the engine shorting the high voltage spark. Replace it immediately unless you feel like wasting more fuel in cold weather starts. The short term cure, until you replace the sensor with the brass one, is to floor the gas pedal completely (that shuts down the injectors) during cold starts, known as "clear flood mode", to enable a reasonable start-up with a flooded engine. A normal start-up in any weather with EFI systems does not require any gas pedal application at all. I did this back in my '77 280-Z and still do this in my '03 L300 today. For you to floor the gas pedal is an indication of something very wrong - the coolant sensor failed.
Old 02-14-2008, 12:51 PM   #8
fredsfix
fredsfix is on a distinguished road
fredsfix's Avatar
1999 SL1
1997 SL1
That ects is sooooo easy to do, sounds like you know what you're doing;
$10 and 20 minutes any you'll be done!
Just for good measure I'd run a can of seafoam through a full tank of gas if you haven't done anything recently to clean the injectors and combustion chamber.
Tip: a very small screwdriver wiggled around down there will pry that darn two wire connector off. I lost about a cup of coolant on each engine I did last week.
You can't call yourself a mechanic if you're surprised it runs!
Add to fredsfix's Reputation
Rate the quality of this post and help fredsfix reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
fredsfix is offline   Reply With Quote
Old 02-14-2008, 01:11 PM   #9
Dr B
Dr B is on a distinguished road
Dr B's Avatar
1992 SL2
1993 SL2
No tools needed ,to remove the C T S plug .....Just squeeze the bell, pull !
My Haynes manual says the same thing, about the prying off (wrong).
All you need is a 13mm deep well socket wrench,relieve any pressure at radiator cap,then install back tight ,then squeeze the bell of the two wire plug,pull off ,then remove the old sender ,then install the new one ,you want to keep the socket straight on ,as you snug the sensor down,replace wire..
Have A Great Day , it is YOUR choice !
Add to Dr B's Reputation
Rate the quality of this post and help Dr B reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dr B is offline   Reply With Quote
02 SL1 No Start when cold cable dude S-Series Tech 19 01-12-2009 09:44 PM
1998 SL1 No Start: No Fuel, No Spark, big Problem tkeahi S-Series Tech 18 11-28-2008 08:02 PM
1998 SL1 Won't Start! JRROGERS S-Series Tech 4 02-20-2008 04:08 PM
1998 SL1 running rich in cold weather. Marko_AF S-Series Tech 11 02-13-2007 09:42 PM
1998 SL1 Stalls when cold. dakota S-Series General 3 12-29-2005 12:56 AM
