Old 07-24-2007, 11:21 PM   #1
tyheid2002
tyheid2002 is on a distinguished road
Default Can't Start My 1998 SC1
I have a 1998 Saturn SC1 with 115,000 miles on it. Saturday night the car wouldn't start.
The battery was dead and so I put in a new battery, new positive and negetive cable, and still have nothing. We attempted to start it last night and it turned over for a short second, which led me to believe that the starter isn't bad. I think that it is the ignition lock cylinder, but I want to know what you guys think about this issue that I am having....
If you guys think that I need to change the ignition lock cylinder, the next question is how hard is it to change it?
Add to tyheid2002's Reputation
Rate the quality of this post and help tyheid2002 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tyheid2002 is offline   Reply With Quote
Old 07-24-2007, 11:36 PM   #2
Default Re: Can't Start My 1998 SC1
Is the starter the original one? Have you checked the connections at the starter solenoid terminals for loose/corroded connections? The large RED and small gauge wire are from the battery and alternator while the small (purple?) gauge wire is the 12v START signal/power wire from the ignition switch. Have someone turn the ignition key to START while you measure the one wire terminal with the purple wire, either with a test light or meter for 12v. Each time the ignition switch is turned to START there should be 12v or a light on at the terminal. At the very same time the starter should engage so be prepared for the engine to start. If there isn't any 12v or light on then there is a wiring or ignition switch problem. Seeing 12v or a light on w/o the starter turning means the starter is dead, the brushes are worn down or the solenoid coil is faulty. Replace the starter. Sometimes rapping the side of the starter with a rubber mallet might loosen the brushes just enough to allow the starter a few more runs. Replace it.
Old 07-25-2007, 12:09 AM   #3
tyheid2002
I forgot to mention that the dome light isn't coming on, the door locks don't work, the power mirror, and the radio also isn't working. The fan, horn, headlights, and dash lights (idiot lights) work. I checked both of the fuse locations and didn't have any problems there.
Old 07-25-2007, 01:32 AM   #4
eljefino
eljefino's Avatar
1995 SW1
All that failed stuff you list runs on the chime fuse.
Add to eljefino's Reputation
Old 07-25-2007, 01:12 PM   #5
DMW
DMW is on a distinguished road
2002 SL
Double check the new battery to make sure its holding a charge.
Add to DMW's Reputation
Rate the quality of this post and help DMW reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DMW is offline   Reply With Quote
Old 07-25-2007, 03:10 PM   #6
What's the voltage at the battery? What else happens (do the lights dim, for example) when you turn the key? Automatic or manual tranny?
If you don't have one yet, your next purchase should be a multimeter. It will pay for itself with the first part you find out you _don't_ need to replace.
Add to madpogue's Reputation
Needing help in what to do for a 1998 sc1 kingcobra S-Series Tech 2 02-23-2008 08:18 PM
1998 Saturn SC1 thewave46 S-Series General 1 03-14-2007 01:07 PM
Transmission question (1998 Sc1) psi4mx5 S-Series Tech 2 02-04-2006 09:05 PM
1998 SC1 Stolen -- Recovered -- Can't start turbo13 S-Series General 13 07-19-2005 07:43 PM
New Engine 1998 sc1 JenniJ S-Series General 1 08-28-2004 08:00 AM
