Old 11-07-2007, 01:27 PM   #1
rearviewmirror
rearviewmirror is on a distinguished road
rearviewmirror's Avatar
Default SL Water Pump Replacement DIY
It sounds like the water pump bearings are going out. I want to replace it myself but couldn't find a how-to document regarding the replacement. I do have the Haynes manual so it won't be a problem.
My question is this, what else along with the water pump should I order/replace parts wise?
Add to rearviewmirror's Reputation
Rate the quality of this post and help rearviewmirror reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rearviewmirror is offline   Reply With Quote
Old 11-07-2007, 01:40 PM   #2
yazhere
yazhere is on a distinguished road
yazhere's Avatar
Default Re: SL Water Pump Replacement DIY
Just a couple of quick things ...in your profile to the left.. post the year of your Saturn.. it will help those who want to help you..
How many miles on your car?
While you are changing the waterpump, great time for new hoses, an ECTS if its never been changed from the plastic resin one, a new thermostat and clean out the reservoir.
Generally the coolant capacity is about seven quarts...
Add to yazhere's Reputation
Rate the quality of this post and help yazhere reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
yazhere is offline   Reply With Quote
Old 11-07-2007, 01:50 PM   #3
richpin06
richpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the rough
richpin06's Avatar
This is not a how-to document but you may find some parts of this video helpful.
http://www.youtube.com/watch?v=nRbUjGLviMY
Add to richpin06's Reputation
Rate the quality of this post and help richpin06 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-07-2007, 01:54 PM   #4
Low Saturn
Low Saturn's Avatar
2000 SC2
http://www.saturnfans.com/forums/sho...30&postcount=5
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2000 SC2
-2001 Chevrolet Suburban
Old 11-07-2007, 01:55 PM   #5
amazinghl
I found the how-to no problem.
http://www.saturnfans.com/forums/sho...ight=waterpump
00 Insight 72mpg
Add to amazinghl's Reputation
Old 11-07-2007, 02:03 PM   #6
Since you'll have the cooling system drained, it'd be a good time to replace the thermostat. If the coolant is old, you might wanna just refill with fresh anti-freeze and distilled water. And of course, if you haven't done it yet, this would be an opportune time to replace the ECTS.
Add to madpogue's Reputation
Old 11-07-2007, 06:33 PM   #7
rearviewmirror
Originally Posted by amazinghl View Post
Dammit! I did search! I just searched for WATER PUMP so maybe it was more pages back then I was willing to look.
The car is a 1996 SL2 w/ 112k miles.
Old 11-07-2007, 06:34 PM   #8
rearviewmirror
Thank ya.. I just did the all 3 ECTS when I did the radiator change. The coolant isn't even a year old yet but I don't think I'm going to try to save it. I'll just refill with 50:50 of new water/coolant. I'll replace the thermostat as well.
Old 11-07-2007, 07:15 PM   #9
amazinghl
I searched for waterpump in the HOW-TO section. It was on the first page.
00 Insight 72mpg
Old 11-07-2007, 07:18 PM   #10
rearviewmirror
i was searching all forums, then the SL forum. I forgot about the How-To forum.
Old 11-07-2007, 07:56 PM   #11
1999greenSL2
1999greenSL2 is on a distinguished road
1999greenSL2's Avatar
You can also go straight to a forum and search at the top of the thread list, where it says "Search This Forum"
Add to 1999greenSL2's Reputation
Rate the quality of this post and help 1999greenSL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1999greenSL2 is offline   Reply With Quote
Old 11-07-2007, 10:14 PM   #12
rearviewmirror
My 1996 SL2 has a Green Sticker on the cap, however, when I changed the radiator out last fall I put DEXCOOL in. I thought all 1996+ cars used DEXCOOL. The car hasn't had any problems running it, and I know the cap is the original OEM cap. Not sure why the green dot is there.
Old 11-07-2007, 10:30 PM   #13
I *think* the very early '96s were still on the green stuff.
Old 11-08-2007, 01:17 AM   #14
rearviewmirror
I'll check the production date in the morning. I don't think there was any harm in running DEXCOOL so far, at least I hope not.
Old 11-08-2007, 11:03 AM   #15
rearviewmirror
Production date:
11/95
Old 11-09-2007, 12:42 AM   #16
Civic&Saturn
Civic&Saturn is on a distinguished road
Civic&Saturn's Avatar
You are correct. The switch to Dexcool did happen sometime in the 1996 model year, but I no longer remember exactly when. Got an SL2 built in October 1995 using the green stuff over here.
Add to Civic&Saturn's Reputation
Rate the quality of this post and help Civic&Saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Civic&Saturn is offline   Reply With Quote
Old 11-21-2007, 04:13 PM   #17
mrbios
mrbios is a jewel in the roughmrbios is a jewel in the roughmrbios is a jewel in the rough
mrbios's Avatar
1997 SW2
Default The switch from Dexcool to green antifreeze...
My 1997 model year SW2 factory order built Aug 2006 and delivered in sept 2006 uses dexcool. I flushed out the dex-cool years ago and switched to the green stuff and have never looked back. I smelled some coolant at around 105K ? but the smell went away. However, the car was stolen and in a light front end accident (radiator not damaged and not replaced).
Previously I always had brown sludge on the radiator cap for the reservoir which is caused by dex-cool being exposed to air. GM is being sued by a ton of owners for the damage dex-cool causes.
I used dexcool in my '92 bmw k75s after I installed a new water pump. The old water pump's fan was spotless at 47K miles & 13 years of service and looked like this:
Less than 3 years later I was resealing my timing cover which required taking the cover off the water pump and it looked like this:
Radiator Cap:
Filler Neck:
Radiator Cap:
Filler Neck:
Keep in mind any dexcool car if switched back to green MUST be flushed: block, heater core, radiator, coolant reservoir. I would do a regular flushing then fill the car with distilled water and get everything hot & heater set to high etc then install the new green stuff mixed 50/50 using distilled water.
I'm the original owner and my car has 122K & 11 years on the original radiator and it still cools great - fan comes on and runs for about 30 to 45 seconds then shuts off. Also, it isn't chronically running like most pre 1996 Saturns. That puts an extra load on the alternator.
Add to mrbios's Reputation
Rate the quality of this post and help mrbios reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mrbios is offline   Reply With Quote
Old 11-21-2007, 04:35 PM   #18
quiksc2
quiksc2 has a spectacular aura aboutquiksc2 has a spectacular aura aboutquiksc2 has a spectacular aura about
quiksc2's Avatar
2002 L-Series 3.0L Sedan
When I replaced my water pump I also replaced the thermostat. I put in new coolant. It was green, but designed to not make the dex cool clump up if mixed. Washed out the reservoir, but didn't flush the system. No problems there.
If I wanted ride quality, I would drive a Cadillac. If I wanted to be a sheep, I would drive something that says Vtec on the side of it...
DCS
Add to quiksc2's Reputation
Rate the quality of this post and help quiksc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
quiksc2 is offline   Reply With Quote
Old 11-21-2007, 04:37 PM   #19
richpin06
richpin06's Avatar
Default Re: The switch from Dexcool to green antifreeze...
That green antifreeze is hard to come by nowadays.
Water pump replacement. awprice S-Series General 29 03-07-2010 01:27 AM
Water pump replacement BASL2 S-Series Tech 9 07-04-2008 12:37 PM
2.2 Water Pump Replacement robotib L-Series Tech 3 01-08-2007 11:05 PM
Water pump replacement BosqueVette98 S-Series Tech 3 03-02-2006 03:09 PM
water pump replacement sonsaturn S-Series Tech 7 12-01-2001 08:31 PM
