Old 04-11-2007, 06:38 PM   #1
Markwthree29
Markwthree29 is on a distinguished road
Default ugh
ok, so im removing the valve cover and i changed out the valve cover gasket and im putting the valve cover back on and i tighten one of the bolts to much( yeah i know, im an idiot) anyway , it breaks off, and know im screwed, its the ****tiest one to break off to. the one all the way to the front left, my dad says go get a reverse drill bit and we will try to get it out, does anyone have any other ideas
Add to Markwthree29's Reputation
Rate the quality of this post and help Markwthree29 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Markwthree29 is offline   Reply With Quote
Old 04-11-2007, 06:41 PM   #2
alleninpa
alleninpa's Avatar
2009 AURA XR
1999 SL1
Default Re: ugh
Weld a Tee handle stud on it?
Drill it out?
Don't use a valve cover?
Sell the car?
EDM sink it out?
Or, you could listen to your dad. Believe it or not, he is older than you and most likely wiser....
Add to alleninpa's Reputation
Old 04-11-2007, 06:43 PM   #3
Markwthree29
Default Re: ugh
so, you think he is right?
Old 04-11-2007, 09:59 PM   #4
tarsun
tarsun is on a distinguished road
Default Re: ugh
ha ha that just happened to me last week.
listen, its all in the preperation...
drill a small hole in the center of the bolt. straight down. it dosent have to be deep at all. just try your best to keep it in the center and straight.
i then used the smallest one of these
http://www.epinions.com/images/opti/...resized200.jpg
and push straight down and go slowely. should come right out.
worked for me
Add to tarsun's Reputation
Rate the quality of this post and help tarsun reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tarsun is offline   Reply With Quote
Old 04-12-2007, 12:44 AM   #5
Default Re: ugh
Have you removed the cover, and determined that there isn't enough busted-off bolt sticking out to grab with a vise-grip or the like? Usually there isn't, but it's worth finding out for sure just how scroooed you are. (ooh, bad pun!)
Add to madpogue's Reputation
Old 04-12-2007, 07:04 AM   #6
alleninpa
alleninpa's Avatar
2009 AURA XR
1999 SL1
Default Re: ugh
worked for me
Doing the same thing, but using a left hand drill is your best option. If the bit grabs with the LHD, then it may just unscrew.
Another option is to use a center punch and tap it in a counterclockwise direction. Did you try to get it out yet at all?
If you sheared it off, it may not be tight, unless you bottomed the screw.
Old 04-12-2007, 07:54 AM   #7
Markwthree29
Default Re: ugh
yes, i removed the cover and tried to grab it with a vice grip, no luck, r those e z outs that u think i should use?
Old 04-12-2007, 07:57 AM   #8
S3aturnR
S3aturnR's Avatar
1999 SL1
Default Re: ugh
either do what your dad said or take it to a professional and have it removed. whatever you do, GET A TORQUE WRENCH!!!
s3aturnr
Add to S3aturnR's Reputation
Old 04-12-2007, 08:18 AM   #9
Glasact
Glasact is on a distinguished road
Glasact's Avatar
2009 AURA XR
2002 L-Series 2.2L Sedan
Default Re: ugh
If you have or know someone with a mig welder, set a nut over the broken stud and weld the nut to it. Has worked numerous times for me.
Next time use a torque wrench: yes:
Add to Glasact's Reputation
Rate the quality of this post and help Glasact reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Glasact is offline   Reply With Quote
Old 04-12-2007, 10:31 AM   #10
tarsun
Default Re: ugh
see my problem was that i dont know how to weld... that and the bolt broke in the head... i did look for some left handed bits... that would have been the BEST way to go as far as drlling the hole for the ez-outs. but the regular bit worked for me.
i also picked ou a tq wrench at the store as well. the guy at the counter knew what was up lol
Old 04-12-2007, 12:21 PM   #11
sl2collector
sl2collector is on a distinguished road
Default Re: ugh
another thing I have done in the past:
use a dremel / die grinder with a cut off disc
cut a slot into the top of the busted stud, then try a big flat blade screwdriver on it.
Add to sl2collector's Reputation
Rate the quality of this post and help sl2collector reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sl2collector is offline   Reply With Quote
Old 04-12-2007, 03:21 PM   #12
Markwthree29
Default Re: ugh
not a bad idea.. i do own a mig welder though....
Old 04-12-2007, 07:56 PM   #13
zoso007
zoso007 is on a distinguished road
1997 SC1
Default Re: ugh
Just replace the whole head.
Add to zoso007's Reputation
Rate the quality of this post and help zoso007 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
zoso007 is offline   Reply With Quote
Old 04-12-2007, 08:20 PM   #14
RalliArt16
RalliArt16 is on a distinguished road
RalliArt16's Avatar
1996 SC1
Default Re: ugh
why does everyone feel the need to put all their strength into tightening bolts. You must have really put a lot of torque on it to break it.
Valve cover gasket bolts go "snug" and thats it
1996 SC1
Add to RalliArt16's Reputation
Rate the quality of this post and help RalliArt16 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RalliArt16 is offline   Reply With Quote
Old 04-12-2007, 10:33 PM   #15
tarsun
Default Re: ugh
just replace the head...???? and ya, well your at it just buy a brand new engine... what do they go for these days? $20.. something like that.
Old 04-13-2007, 11:34 AM   #16
Default Re: ugh
That's a tad bit high for Low Saturn....
Need some help... ugh OnDaGround Miscellaneous Tech 6 08-01-2008 02:47 PM
Ugh. Sunroof quiksc2 S-Series Tech 6 10-31-2007 03:54 PM
ugh ugh ugh! agoldslsaturn S-Series General 33 04-21-2006 02:43 PM
Ugh... J.H. L-Series General 3 03-04-2006 02:41 AM
