Old 05-16-2018, 02:32 PM   #1
onlinebiker
Default 93 SW2 sudden loss of oil pressure
Got my 93 SW2 home.
Story from previous owner ( second hand info) the original owner - from southern Indiana was in Holland Michigan a few weeks back - and had the oil light come on - and a bit of lifter noise developed at the same time.
Any likely culprits come to mind?
I' ve been over this car - and it' s by far the cleanest gen one car I' ve seen. Interior near perfect, only a couple scratches in the paint - all the clear coat is still good. It even came with good Firestone tires. Just under 80 k miles.
I' D be happy even if I need to get a new engine for it.
92 SC2
93 SC2
93 SW2
95 SC2
97 SL2
97 SC2
99 SC2
02 SC2
02 SL2
parts
2 94 SC2 parted out
3 96 SC2
Old 05-16-2018, 02:35 PM   #2
Default Re: 93 SW2 sudden loss of oil pressure
Pressure switch failure. The switch is a 14mm X 1.5mm and with an adapter to 1/8 TIP you can connect a real gauge and see whats up but as it is a 5-7psi switch that is the first guess and the 2nd is something hard went through the oil pump and cut grooves in the pump cavity.
Old 05-16-2018, 02:46 PM   #3
amazinghl
Get a mechanical oil pressure gauge and measure first!
00 Insight 72mpg
Add to amazinghl's Reputation
Rate the quality of this post and help amazinghl reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
amazinghl is offline   Reply With Quote
Old 05-17-2018, 01:44 PM   #4
onlinebiker
Got a mechanical gauge, pulled the sensor - plumbed in mechanical line and starter it up.
Flat line.
Zero pressure.
Checked gauge. Gauge tests good.
Guess I' m pulling and rebuilding this one.
Cool. Can pull the bottom end, and put oil return holes in the oil ring groove.
This sucker will run a million miles.
92 SC2
93 SC2
93 SW2
95 SC2
97 SL2
97 SC2
99 SC2
02 SC2
02 SL2
parts
2 94 SC2 parted out
3 96 SC2
Old 05-17-2018, 02:01 PM   #5
Pistons must come out the top and the pressure failure is probably in the timing cover. You must find out exactly what caused this failure or it will happen again.
Old 05-20-2018, 12:32 AM   #6
onlinebiker
Agreed. Plan on total disassembly. I'm guessing either the overpressure valve came out, or the key sheared.
92 SC2
93 SC2
93 SW2
95 SC2
97 SL2
97 SC2
99 SC2
02 SC2
02 SL2
parts
2 94 SC2 parted out
3 96 SC2
Old 05-20-2018, 09:03 AM   #7
OPV is far from failure prone but a chunk of plastic guide will jam it open. Most likely cause is guide fragments in the pump and the timing cover recess is now sufficiently scored that all oil bypasses the pump back to the suction at low RPM. The pump is driven by the crank key and they do not shear.
93 SW2 sudden loss of oil pressure onlinebiker S-Series Tech 4 05-18-2018 07:11 PM
sudden power loss. scbill S-Series Tech 21 05-11-2016 04:17 PM
Help with Sudden Oil Loss AndreasChen S-Series Tech 15 01-19-2010 01:58 AM
Help! 92SL2 Sudden Loss of Oil Pressure drumr S-Series Tech 46 03-07-2005 12:12 PM
Sudden Coolant Loss David 93 SL2m S-Series Tech 4 07-15-2001 06:41 PM
