Old 05-17-2018, 09:53 PM   #1
Jalpom
Jalpom is on a distinguished road
Default 1992 sl2 steering issues
I got 92 sl2 twin cam. Steering is very loose. When i hit bumps it jerks to whatever side hit the bump. Clicking noise now when i drive. Bad outside tire wear. Replaced control arms. Thought bearings to. But not completly sure
Add to Jalpom's Reputation
Rate the quality of this post and help Jalpom reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jalpom is offline   Reply With Quote
Old 05-19-2018, 06:17 PM   #2
Default Re: 1992 sl2 steering issues
Welcome to SaturnFans, Jalpom!
Loose steering may be caused by a deteriorating condition with the rack and pinion gear, worn tie rod ends, badly worn rack and pinion mountings, and sometimes even worn CV axles.
1) Are the struts in good condition?
2) What is the condition of the engine cradle? (Has it ever been removed and reinstalled for any reason?)
This kind of noise may relate to a bad CV joint. To test CV joints, go to a place where you have plenty of room to execute hard left and right turns in both forward and reverse directions. Lower the driver and passenger windows and listen for the clicking noise and which side it may emanate from. If this is the cause then the sound will be reasonably strong and very metallic in quality.
1) How long ago?
2) Who installed them?
3) Was the vehicle aligned afterwards? Tire wear as described above indicates a bad alignment condition. See the descriptions in the link below.
https://www.bridgestonetire.com/trea...ad-wear-causes
Can you go back through your repair records to confirm this either way? To the greatest degree possible, provide as much specificity about the repair history of your car with regard to this suspension and tire wear problem.
Lastly, repost this message in the S-Series Forum. It will receive many more helfpul responses if you do so.
293,000 miles-it keeps on rolling!
Add to pierrot's Reputation
1992 SL2 Transmission Issues GaHansen S-Series Tech 4 05-06-2009 09:49 PM
1992 SL1 Cranking Issues HELP! Jakeblews S-Series Tech 1 02-28-2008 10:09 PM
1992 SC2 Clutch Issues lowblackdub S-Series Tech 3 01-06-2008 06:21 PM
Serious Wiring Issues [1992 SL2] Jaidyn S-Series Tech 7 07-31-2007 07:24 PM
1992 SL2 Series Seatbelt Issues LizzeAnn S-Series General 3 08-01-2005 12:12 PM
