Old 05-17-2018, 09:55 PM   #1
chip707
chip707 is on a distinguished road
Default Engine swap
I just bought a Saturn sl2 2001 for $200.00. The car front fender and knuckle is damage but the engine is in tact and has 85k miles. My engine on my Saturn sl2 2002 is having problem with knocking and oil leak. Iím going to swap the engine I just need to know while I have the engine out what else should be replaced while I have the engine out? I know spark plugs maybe new water pump. Should I re do the sealant for the valve cover and oil pan to save me time in the future . Thanks for the help in advance
Chip
Add to chip707's Reputation
Rate the quality of this post and help chip707 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
chip707 is offline   Reply With Quote
Old 05-18-2018, 06:43 AM   #2
Waiex191
Waiex191 has a spectacular aura aboutWaiex191 has a spectacular aura aboutWaiex191 has a spectacular aura about
Waiex191's Avatar
Default Re: Engine swap
If the oil pan, cam cover, and water pump are not leaking now, I'd leave them alone!
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 05-18-2018, 07:34 AM   #3
Nekomimi
Nekomimi is on a distinguished road
Nekomimi's Avatar
1996 SL1
Edit, nvm, I just comprehended all the details in the op, ignore this. ^ .^'
'96 SL1 Originally the family car, passed on to me as my first. "Hellcat" 240,000+ miles and purring smooth.
My Mug is filled with the lost souls of imports.
Add to Nekomimi's Reputation
Rate the quality of this post and help Nekomimi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Nekomimi is offline   Reply With Quote
Old 05-18-2018, 09:33 AM   #4
How much do you want to spend?
Assuming you are a cheap and lazy bastidge like I am, while the engine will be out . . .
  • gently backflush the heater core (that's staying in your old car, how many miles does that have?)
  • check/replace the ECTS as needed
  • clean EGR, remove exhaust manifold and clean EGR and AIR passages
  • replace the top starter bolt with a stud to make future replacement easier
  • Check that plastic coolant nipple or whatever that is under the 3rd gen intakes and breaks/ leaks all the time, replace if not already done
  • serpentine belt if needed
If a manual trans, new clutch? with only 85k miles, assuming the donor car was cared for, I wouldn't think it would need much.
Old 05-18-2018, 02:00 PM   #5
Highmile
Highmile's Avatar
Replace the rear heater hoses. They are easy to get to with the motor out but a total pain with the motor in place.
actually if it were me I'd replace anything that was old or questionable but then again I drive my car a TON.
My list would be
heater hoses
radiator hoses
belt
motor mount if it needs it
dog bones if it needs it
axle seals (if you pull the trans too)
Good Luck
Highmile
'95 SL1 657k and counting
Add to Highmile's Reputation
Rate the quality of this post and help Highmile reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Easier to Swap engine, or swap tranny? Saturn #4 S-Series General 6 03-21-2016 08:44 AM
Engine cradle swap; tranny swap MikeNW S-Series General 6 03-11-2015 12:04 AM
Engine swap help. Can you swap without taking off the transmission? 99 sl2 5-speed msmay0 S-Series Tech 5 06-10-2012 04:01 PM
engine swap ? 99 sl2 swap in 98sl2 jiffypop S-Series Tech 1 12-11-2010 10:14 AM
Engine Swap or trannie swap SL-2er Miscellaneous Tech 1 04-28-2003 04:00 PM
