Old 05-17-2018, 02:55 PM   #1
gmcelroy
gmcelroy is on a distinguished road
Default Input Shaft Nut - Amount of ATF Loss
How much fluid do you lose when removing the transmission end cover to replace the input shaft nut?
FYI, I just changed the ATF 2K miles ago (with Mobil 1) so I do not want to drop another $50-$60 on a complete drain/refill so soon.
Add to gmcelroy's Reputation
Rate the quality of this post and help gmcelroy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gmcelroy is offline   Reply With Quote
Old 05-17-2018, 03:09 PM   #2
Default Re: Input Shaft Nut - Amount of ATF Loss
Jack the left side up as high as you can get it ad let the car sit for 10-15 minutes. Then remove the cover. Be sire to cover frame and mount so the couple of ounces left in the cover do not run onto the mount or make a mess. If you collect and measure it you will have an exact value but it is not much.
Old 05-17-2018, 04:39 PM   #3
gmcelroy
Thank you OldNut....It sounds like if I buy one quart of Mobil 1 ATF that should cover the loss (and then some)......
Old 05-17-2018, 05:41 PM   #4
Yes, that should do it.
Normal Amount of Coolant Loss? actionstan S-Series Tech 4 10-28-2013 11:05 PM
input shaft shadowspiyre99 S-Series Tech 2 09-15-2010 02:44 PM
input shaft nut-shaft play chingondearmona S-Series Tech 9 06-30-2010 08:23 PM
how to jam input shaft for input shaft nut replacement. anisbet S-Series Tech 2 04-20-2009 11:54 AM
Amount of coolant loss acceptable? JerryHughes S-Series General 21 09-26-2005 08:17 PM
