Old 04-02-2003, 05:16 PM   #1
Twin_Cam
Twin_Cam is on a distinguished road
Twin_Cam's Avatar
2000 SL2
Default Wrapping header/manifold?
I was looking through the performance accessories on carparts.com (looking for Oil Press. and Volt gauges) and noticed "Header/Manifold Wrap," a thermal tape you wrap around the header. My first thought was oh, that would help power because it would keep the 'underhood' area cooler.
And then another thought came to me: It would help emissions also, because the heat of the exhaust would stay in the exhaust system, instead of radiating into the engine bay. This saved heat would heat the catalytic converter up faster, improving emissions.
Sound feasible? I'm not saying I'm going to do this now, but when I do my performance engine rebuild in summer 2004 (hopefully), I might try this.
'00 SL2m- DD, 186K miles
'05 Honda CR-V- wife's DD and my upright bass hauler
'84 Honda CB650SC Nighthawk- toy
Twin_Cam is offline
Old 04-02-2003, 05:34 PM   #2
eRic 02sc2
eRic 02sc2's Avatar
Default
sure. btw you can wrap a 91-92 header while it's on the car if move the a/c compressor out of the way. use ramps or jackstands to lift the car so you can do the bottom.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
eRic 02sc2 is offline
Old 04-02-2003, 08:21 PM   #3
Applefool
Applefool has a spectacular aura aboutApplefool has a spectacular aura aboutApplefool has a spectacular aura about
Applefool's Avatar
2006 ION Red Line
Default
Speaking of a/c compressor.. I was noticing how close it is to the exhaust manifold in my 95 SL2, and wondering if I will have any issues with header installation?
2011 Audi TT (modified)
2007 Mercedes E550 (stock)
1999 Expedition (Stock)
2007 Ion Coupe (Daughters eventually)
Applefool is offline
Old 04-03-2003, 12:39 AM   #4
Airforce1
Airforce1 is on a distinguished road
Default
You will have to remove belt;easy, unbolt ac compressor;easy and flop it out of the way.
Airforce1 is offline
Old 04-03-2003, 01:22 AM   #5
amazinghl
Default
Yup... and you have to have a shop to WELD the flexpipe to the cat for you. I'd recommand you replace the flexpipe first before you weld it in.
00 Insight 72mpg
amazinghl is offline
Old 04-03-2003, 01:37 PM   #6
eRic 02sc2
eRic 02sc2's Avatar
Default
you have to remove the serpentine belt and unbolt the bracket from the block and move the a/c compressor out of the way before removing and installing the manifold and header.
eRic 02sc2
OBX Header/Manifold, no fart canon. Mgg4591 S-Series Mods 22 12-13-2009 10:45 PM
WTB Header, and Turbo manifold for 01 DOHC remedys Classifieds 1 07-06-2006 05:31 PM
Turbo Manifold/Header LvnInPeace Mods and Performance 16 09-22-2003 08:45 AM
91/92 exhaust manifold header question superfreak S-Series Tech 5 02-06-2003 10:28 AM
Header vs. Exhaust manifold Question piratepress Miscellaneous Tech 2 06-06-2002 09:08 PM
