Old 06-18-2018, 10:29 PM   #1
legaspi89
legaspi89 will become famous soon enough
2003 L-Series 2.2L Sedan
Default Loose Part on Front of Dash
On my Saturn 2003 L200, I have a loose plastic piece which is in front of the dash. What would be the best way to put it back in place? I was thinking of Adding Strong Glue for Plastic. Here is the video to show what I'm talking about.
https://www.youtube.com/watch?v=SVXLX6h4aY8
Add to legaspi89's Reputation
Rate the quality of this post and help legaspi89 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
legaspi89 is offline   Reply With Quote
Old 06-19-2018, 02:18 PM   #2
floridasl22002
Default Re: Loose Part on Front of Dash
The part you are showing us is a plastic part that clips in place BUT is very prone to disintegrating due to a) being plastic and b) where it is located and thus getting the full force of the sun. You remove it by grasping it and pulling upwards and towards you.
If is breaking up, it is past saving and terminal. The part, like most trim parts is no longer available. Your main source besides Ebay is going to be the junk yard. My son has a 2003 L300 and his did exactly the same. After a trip to the JY, we found one in one piece, that came off in one piece and after over 12 months is standing up well.
Hope this helps
Old 06-19-2018, 09:06 PM   #3
legaspi89
Thank you for the feedback. I'll probably take the same route in terms of going to the Junkyard to locate that piece.
Plastic Part Under Radiator - Loose/Flapping datlas S-Series General 6 03-27-2015 03:34 PM
Exauhst pipe loose part, help TigerXiao S-Series General 4 07-14-2014 08:43 AM
Space between dash pad and front dash panel jsevinsk S-Series Tech 4 08-09-2011 02:33 PM
Rear stablizer bar loose inside of rubber part nmsaty S-Series General 0 04-14-2006 02:11 PM
Help!, Suspension/drivetrain part loose. ProDarwin Miscellaneous Tech 12 06-14-2003 03:51 PM
