Old 11-02-2008, 07:38 PM   #1
Ackpacket
Ackpacket is on a distinguished road
Default Cooling down
Can I get some information on the cooling system in the front of a car? I'm not trying to repair anything but it'd be nice to be able to decipher that jumple of things behind a grill.
Here's where I'm confused. How do the radiator, transmission cooler, and condensor work together? Are they each a seperate finned assembly that each gets its shair of air flow through it? Or, are some or all of them combined in some way? How do the fluids flow seperately through these structures if they are combined?
For example, I just took a look at a ford escape. I see one finned assembly with two coolant hoses running to it. So that must be the radiator. In front of that is another finned assembly with the A/C hoses running to it on the passenger side, and transmission lines running to it on the driver side. So does this assembly function as both the transmission cooler and the condenser? If so, how do the fluids keep seperate?
What can I expect to find on my S-series? Which units are combined/seperate?
Thanks for any useful info guys!
2002 sl2 DOHC 126k miles
Add to Ackpacket's Reputation
Rate the quality of this post and help Ackpacket reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ackpacket is offline   Reply With Quote
Old 11-02-2008, 08:03 PM   #2
PurdueGuy
PurdueGuy's Avatar
1999 SC1
Default Re: Cooling down
The AC condenser is bolted to the front of the radiator, and is a fully separate unit. The trans cooler (which is only used on the autos) is built into the radiator. Air flows through the condenser then the radiator.
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Old 11-02-2008, 09:26 PM   #3
eRic 02sc2
eRic 02sc2's Avatar
check this out?
http://www.autozone.com/shopping/rep...00c1528017e86a
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
cooling fan comes on too soon iluvmud069 S-Series Tech 8 10-07-2008 08:15 AM
Cooling Fan Again richamer1 Ion General 4 10-05-2008 02:06 PM
cooling problem buddyc S-Series Tech 0 08-11-2003 12:32 PM
A/c Temp/cooling 9TWOSC Miscellaneous Tech 2 06-15-2003 10:39 PM
Cooling 91SL2 Miscellaneous Tech 6 06-07-2001 11:04 PM
