Old 10-09-2008, 10:38 PM   #1
Artemis
Artemis is on a distinguished road
Default 94 Saturn SL - Still not starting. Video -
So I'm still having issues trying to get this thing to fire, I've uploaded a video, have a look and see what you guys think.
The downpipe isn't connected to the exaust, which is why the car sounds a little more grimey then it really should.
The car backfires early in the clip (much to the amusement of my brothers) and then we kept trying with no luck.
http://video.google.ca/videoplay?doc...69028&hl=en-CA
The guys that are helping with the job think it could be timing, as we have fuel/spark/air.
Any help / insight would be appreciated.
Add to Artemis's Reputation
Rate the quality of this post and help Artemis reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Artemis is offline   Reply With Quote
Old 10-09-2008, 11:21 PM   #2
Default Re: 94 Saturn SL - Still not starting. Video -
How do you have the plugs wired? If you can smell fuel at he exhaust manifold and you have spark it should run. The one backfire indicates that the firing order is incorrect. Also, twiddling the throttle will keep it from starting, or make it more difficult. The tag on the radiator support shows the proper firing order.
Old 10-09-2008, 11:22 PM   #3
You may have a rare classic case of too lean a fuel/air mixture with backfiring. This is from the original engine coolant temperature sensor (ECTS) failure. Too lean a mixture does result in backfiring right into the intake manifold. Most coolant sensor failures result in too rich a mixture but there have been occasional leaned out conditions with backfiring as the symptom. There's a How-to library near the top with videos, pictures and procedures. Replacing it costs less than $20 and takes 5-minutes. Any auto store stocking the two-wire brass sensor will work.
If the firing order is incorrect; engine from left to right is 1234, ignition wiring is 4123 from the coils left to right.
Old 10-10-2008, 03:20 AM   #4
Ackpacket
Ackpacket is on a distinguished road
+1 ^^^^ on the ects.
Did I do ^ that right?
Personally wouldn't crank the starter that long. I'm paranoid about burning it out.
You could always try putting a smidgen of gasoline in through the brake booster or pcv line. See if that helps get it started. I'm just going on the possible lean condition suggestion from fdryer. You never know right? Watch your face, keep it away from the lines and engine when you do this. Always keep a properly rated fire extinguisher handy as well.
Check for spark and compression. Go back to basics.
Sorry but that's all I can think of. Keep us posted. As helpful as this forum is your car should be running in no time if you can answer questions and follow directions.
2002 sl2 DOHC 126k miles
Add to Ackpacket's Reputation
Rate the quality of this post and help Ackpacket reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ackpacket is offline   Reply With Quote
Old 10-10-2008, 09:36 AM   #5
Artemis
I'll check this sensor, what does it look like and where is it located? I also may have the firing order incorrect, i'll have to check that out. ALSO, I'm not 100% sure we got the timing right. Is there a guide to the timing for this car? I don't really feel like having belt valves.
Old 10-10-2008, 09:55 AM   #6
BarnOwl
BarnOwl's Avatar
Use the forum jump at the bottom of this page and go to the How-To Library. The second and third posts tell you what you need to know about thre ECTS.
The wiring order which is a little different than the firing order is as follows. Going from passenger side to driver's side the cylinders are numbered 1 through 4. On the coil packs from passenger side to driver's side they connect 4, 1, 2, 3.
Did you change the timing chain on this car? If that's off, you've got some bent valves. A compression test should make this evident. If you're talking about spark timing, the PCM controls that and there's no adjustment.
Add to BarnOwl's Reputation
Old 10-10-2008, 10:03 AM   #7
Artemis
The timing chain was changed, but we were fairly certain we got the timing right at the time... not 100% sure now though. Is there a guide in the how-to for setting the timing?
Old 10-10-2008, 10:12 AM   #8
BarnOwl
BarnOwl's Avatar
Not that I know of. Low Saturn's posted some decent pics. You might do a search for those. If you got the colored links where they belong, you should be okay.
Old 10-10-2008, 10:34 AM   #9
Artemis
What do you mean, colored links?
Old 10-10-2008, 11:07 AM   #10
I think what BarnOwl means is one or two links are painted as timing references for easier set-up. The pictures display them.
Old 10-10-2008, 12:18 PM   #11
BarnOwl
BarnOwl's Avatar
My mistake, I was thinking about a DOHC. I really don't know whether it applies to an SOHC.
Old 10-10-2008, 12:32 PM   #12
There is a pip and painted link that align on the cam sprocket when the crank sprocket is on the mark with #1 on compression and the painted links will be directly opposite the crank timing mark.
Old 10-10-2008, 03:31 PM   #13
rc1488
rc1488's Avatar
+1 on replacing the ECTS. Be sure to change the one with the two wire connector.
:/ I think you need to look at a service manual.
If your asking about the painted links, that clearly means you didnt know they were there. Which then indicates your timing may possibly be off.
http://www.therob.com/enginebuilding/build.php
This is for a DOHC. However the concept is the same for a SOHC.
Add to rc1488's Reputation
Old 10-14-2008, 09:42 AM   #14
Artemis
took off the chain cover this weekend, fixed the timing, I found Low Saturns guide which made it very simple... minus the whole taking the chain cover off ofcourse. The car is still not starting though. Where is the ECTS sensor located? I could replace it no problem if I knew where it was. Btw, the spark timing was always correct, we had 4123 to begin with. Another important thing to note is that we're hot starting the starter with the key to position ON. For some reason turning the key won't start the starter. While on ON it does however give us spark.
Old 10-14-2008, 10:52 AM   #15
JADEDSL2
JADEDSL2 will become famous soon enough
JADEDSL2's Avatar
Location: Sullivan, Missouri, USA, North America, Northern West Hemisphere, Earth, Solar System, Left Galactic Arm, Milky Way Galaxy, Local Galactic Cluster, Universe
1993 SL2
1991 SL2
If you "fixed" the timing, and you had it wrong before and were trying to start it, you probably have bent valves and no/little compression. Also, The ECTS is located on the drivers side of the cylinder head behind and below the coolant hose that goes to the radiator, and in front of and below the EGR valve. Your 94 will have 2 sensors there. One with 1 wire controls your guage inside the car, the other with 2 wires goes to the pcm. Saturns will NOT start if the ECTS is dead. If it's bad, sometimes they'll start and sometimes not. Get a brass tipped one from a Saturn dealer. Aftermarket ones aren't as good. AND, your key probably won't turn the starter over for any number of these following reasons:
Dead ignition switch.
Dead starter relay.
Bad clutch/starter interlock switch (if you have a manual transmission)
Bad wiring between any of these components.
Good luck.
"1G8ZJ5472MZ134321"-my Jaded, I will never forget.
"1G8ZF5594PZ249184"-Trinity, for three are now one.
Add to JADEDSL2's Reputation
Rate the quality of this post and help JADEDSL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JADEDSL2 is offline   Reply With Quote
Old 10-14-2008, 10:57 AM   #16
EvilSL2
EvilSL2 is on a distinguished road
EvilSL2's Avatar
2001 SL2
Ok how did the car get in to this state?
You might want to double check you spark plug wires and make sure they are not mixed up and have the fireing order reversed.
Jeremy Vickers
01 Saturn SL2 auto.
"For every abused saturn, Wolfman kills a kitten."
Add to EvilSL2's Reputation
Rate the quality of this post and help EvilSL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
EvilSL2 is offline   Reply With Quote
Old 10-14-2008, 11:39 AM   #17
EvilSL2
EvilSL2's Avatar
2001 SL2
Sorry, the only thing that would load was the first post.
Jeremy Vickers
01 Saturn SL2 auto.
Old 10-14-2008, 11:41 AM   #18
Artemis
Okay, so I know exactly which sensor is the ECTS now, and I'm 99% sure thats the problem here, it looks like its seen better days. Spark plug positions are correct as from the coilpack they're going 4123.
Old 10-14-2008, 11:43 AM   #19
Artemis
haha, no worries!
Old 10-14-2008, 11:15 PM   #20
Artemis
replaced ECTS, still no go.... any other thoughts?
my Saturn in a video! eRic 02sc2 General Saturn Discussion 3 12-28-2009 11:12 PM
Best saturn VIDEO EVER!!! bobyjones S-Series Tech 26 07-17-2009 08:49 AM
'95 Saturn SC-2 Video DB_Racing S-Series General 5 11-17-2006 02:41 AM
Saturn vs. camaro VIDEO nmsaty S-Series General 13 07-27-2006 07:13 AM
Starting timing chain how to video Nowhere Man S-Series Tech 27 07-15-2004 01:14 PM
