Old 04-28-2008, 03:36 PM   #1
SalemCat
SalemCat will become famous soon enough
Default Is my Thermostat broken ?
My 1995 SW2 was running cool all the time; the Temp Gauge was only 1/3 of the way up, so I replaced the Thermostat. It runs with the Temp Gauge halfway now, which I believe is fine.
So now I'm testing the old Thermostat. First of all, it does not open until 250F or so; way too high. This would make the engine run too hot though, not cool as it was doing.
So I looked at the Thermostat when it was cool. I ran water from my home faucet into the Inlet (Outlet?) of the aluminum Thermostat Housing. The water runs right through without restriction. The rubber gasket never contacts the sealing surface inside at all.
My question: When the Thermostat is cool, should the rubber gasket close completely ? Should it be possible for the water to pass right through as it does on this old Thermostat ?
Add to SalemCat's Reputation
Rate the quality of this post and help SalemCat reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SalemCat is offline   Reply With Quote
Old 04-28-2008, 03:47 PM   #2
daddio
daddio is on a distinguished road
daddio's Avatar
Default Re: Is my Thermostat broken ?
from what you describe is happening with your old thermostat, it sounds like it was/ is stuck open. they can do that and it will not let your engine warm up properly. the temp gage reading just below 1/2 is fine.
Add to daddio's Reputation
Rate the quality of this post and help daddio reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
daddio is offline   Reply With Quote
Old 04-28-2008, 06:21 PM   #3
WingsOfSaturn
WingsOfSaturn's Avatar
Thermostats are designed to stick open when they go bad. Stop the system from overheating.
Bet you MPG have gone up now too.
97 SL2 AT 150K Original Owner
95 SL2 MT 220K+
My Saturns have BRASS ones!
Old 04-28-2008, 10:51 PM   #4
SalemCat
Thanks all !
You know, I'm pretty sure this is the original thermostat, and at 13 years and 115K this car has always run cold. I think it was bad from the start.
Anyhow, it's my second car, so I've been averaging a Tank of Gas every 60 days ! It will take me a while to see what the MPG is now.
But yeah, I'll bet it's better than the 22 MPG it's been getting.
Old 04-29-2008, 04:17 PM   #5
Signmaster
Our '95 SL1, and quite a few other cars from what I've seen here, ran cooler from the factory. When the thermostat finally went the unit rated at the same temp brought the gauge up to almost exactly 1/2. It never got much above 1/4 from the factory.
Old 04-29-2008, 04:31 PM   #6
SalemCat
That's interesting - and exactly my experience.
For chuckles I placed my old Thermostat in the Freezer; so cold my fingers stuck to it when I took it out. THEN it was closed. So I ran cold water into the outlet, and it held water - for 2 or 3 seconds. Then it was warm enough (probably 50 degrees F) to open and all the water ran out.
I tossed it in the trash.
Old 10-31-2008, 12:29 AM   #7
curtdog18
curtdog18 is on a distinguished road
ok i have a 97 saturn SL2 SOHC i bought it from a friend it didnt have a hood,fender,bumper headlights. so i went with the guy i bought it from to get replacement parts and all of that for only a case of beer ha.
but ne ways in the summer the coolant fan didnt work and the car heated up to half which i thought was high cause my old car read 1/4 and it was fine but its getting cold now and the car stays at 1/4 while driving and when it idles it hits a little over 1/4 and the heat well doesnt work too well its always cold maybe once when i turn on the heat it works but thats it. i let it heat up checked the heater core hoses 1 was hot the other was cold so i think it might be a clogged heater core but after reading this maybe its both i have horrible MPG it only gets about 230 miles a tank of gas and its only a 10 gallon tank so im guessing 23 mpg and thats not good for a saturn
also i have a surge performance chip and it does nothing to the car DONT BUY THESE SCAMS it also has a CAI (cold air intake) idk why i put that in but thats it plz plz send ur opinions!!
Add to curtdog18's Reputation
Rate the quality of this post and help curtdog18 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
curtdog18 is offline   Reply With Quote
Old 10-31-2008, 01:40 AM   #8
rc1488
rc1488's Avatar
Change your ECTS first off. Yours is resin and most likely the most degrading factor of your low MPG.
Also, untill you have a brass ECTS, all temperature readings are VOID. They will not be accurate and cannot be used for diagnosis untill a new ECTS is in the engine
Also, what kind of car do you have? An DOHC is an SL2. A SOHC is an SL1.
Add to rc1488's Reputation
Old 10-31-2008, 07:36 PM   #9
Neat trick. How do you get water to 250F? That is the way you are supposed to check it out of the car.
The thermostats in the S-series ususally fail open. I have seen them where the gaskets have just rotted out letting the coolant flow through them as well.
Add to ssicarman's Reputation
Old 11-01-2008, 10:05 PM   #10
Signmaster
With two senders, the ECTS won't change the temp reading unless it was actually gone and causing mixture problems and altering the running temp.
The original resin ECTS in our '95 was still working fine when I replaced it, and spec'd better than the new one.
Old 11-06-2008, 01:31 AM   #11
curtdog18
ok well im goin to check the ECTS i need to fix this im almost out of gas and only gone 230 miles also i just hit 150,000 yay! or maybe thats when things go down hill i doubt it
10 gallons of gas 230 miles = 23MPG <<<<BAD
Old 11-06-2008, 03:06 AM   #12
Ackpacket
Ackpacket is on a distinguished road
Agreed. The thermostat needs to be checked in water, which boils at 212 if I remember right. The boiling doesn't let it rise much above 212 so... ?
2002 sl2 DOHC 126k miles
Add to Ackpacket's Reputation
Rate the quality of this post and help Ackpacket reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ackpacket is offline   Reply With Quote
Old 11-06-2008, 03:07 AM   #13
rc1488
rc1488's Avatar
I was actually replying to CurthDog who said he had a '97. I should have quoted him since he wasnt the OP. Sorry!!
Old 11-07-2008, 02:13 PM   #14
albanianmafie
albanianmafie is on a distinguished road
I replaced the ECTS and the car got better milage. The temp read about quarter way. I hear that it should read more, and so i replaced the thermostat but it still reads the same. I also didnt change the rubber ring that goes on there, the new one was bigger so i just left the old one on there. It seemed that coolant had been leaking out of there.
My question is that the fan doesnt work when i turn on the car or the AC, could this be a ECTS connector or a fan motor??
Any opinions are appreciated
Add to albanianmafie's Reputation
Rate the quality of this post and help albanianmafie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
albanianmafie is offline   Reply With Quote
Old 11-07-2008, 03:36 PM   #15
The o-ring fits. You have to start it into the grove and work it around, its slightly compressed. If the old one is leaking then it needs to be replaced. Check your ECTS connector carefully for corrosion. Fan failure could be a fuse, fan relay or motor. Check How-To Library for the videos on testing it out.
Old 11-07-2008, 07:41 PM   #16
curls
curls is on a distinguished road
1992 SC2
Did you see any change in performance, drive? This thread proves to me I need to change my thermostat, but wondering how much it's connecting to other issues.
Add to curls's Reputation
Rate the quality of this post and help curls reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
curls is offline   Reply With Quote
Old 11-07-2008, 08:15 PM   #17
Gambit
Gambit is on a distinguished road
Gambit's Avatar
1995 SW2
I also have a 95 SW2
When I changed the Thermostat two years ago the mileage went from 25 city/ 28 highway to 30-31 city/ 35-41 highway.
That's worth a $15 part and 30 minutes of my time!
Add to Gambit's Reputation
Rate the quality of this post and help Gambit reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Gambit is offline   Reply With Quote
Old 11-08-2008, 01:51 AM   #18
curls
1992 SC2
30 minutes?
How do you do it that fast? I thought you had to get under the car & also drain the radiator?
Did you see any drivablity problems change too?
Old 11-08-2008, 03:14 AM   #19
rc1488
rc1488's Avatar
Originally Posted by curls View Post
30 minutes?
You do. It doesnt take that long tho. There are 2 drain plugs. One on the bottom of the water pump and one on the radiator. Watch richpins videos and youll see what im talking about.
Define "drivability problems". No it does not fix the crazy driver behind the wheel SOrry :P
Old 11-08-2008, 05:21 AM   #20
curls
1992 SC2
I guess I'm being elusive. I meant performance of the car, like this problem that I'm having:
http://www.saturnfans.com/forums/sho...d.php?t=128605
It's my new tire purchase I'm counting on to fix my crazy driving habits.:yes
Thermostat Razzor19 L-Series Tech 3 02-13-2010 01:18 PM
Thermostat 1995sl1sohc S-Series Tech 5 10-29-2008 07:45 PM
thermostat hghghg S-Series Tech 10 10-26-2008 12:08 PM
Thermostat? Rapsack S-Series Tech 1 01-06-2008 02:42 PM
thermostat 92saturnsl2 S-Series Tech 23 11-06-2002 07:08 PM
