Old 08-03-2010, 11:28 PM   #1
Ackpacket
Ackpacket is on a distinguished road
Default valve cover gasket substitute
Can I use ONLY rtv to form a gasket for my valve cover? My thoughts were this: put in enough rtv to fill the groove in the valve cover and stand a bit proud. Put the valve cover on hand tight. Allow the rtv to cure completely and it should be in the same shape as a molded gasket, filling the groove and flattening between the cover just like a molded gasket, and should be the same hardness as a molded gasket. Then I can torque the cover down completely and it should compress (not smush/smear) and add tension to the cured rtv just like a gasket. Thoughts?
2002 sl2 DOHC 126k miles
Add to Ackpacket's Reputation
Rate the quality of this post and help Ackpacket reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ackpacket is offline   Reply With Quote
Old 08-03-2010, 11:44 PM   #2
madpogue
1996 SW2
Default Re: valve cover gasket substitute
Year and model?
Add to madpogue's Reputation
Old 08-04-2010, 06:26 AM   #3
Ackpacket
2002 sl2 dohc
Old 08-04-2010, 09:03 AM   #4
If you have to pull the cam cover off again for any reason, you're going to really hate yourself for having used RTV last time
Old 08-04-2010, 12:52 PM   #5
Low Saturn
Low Saturn's Avatar
2000 SC2
Go for it.
If you plan on immediately selling the car to someone you don't like and will never see them or the car ever again.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2000 SC2
-2001 Chevrolet Suburban
Old 08-04-2010, 03:13 PM   #6
madpogue
1996 SW2
What would be the point? Don't tell me it's to save the $25 on the gasket. Given the time you'd be spending on this method, you're not paying yourself much. Even if your time were free, $25 over, say, 100,000 miles is a penny every 40 miles.
Old 08-04-2010, 06:06 PM   #7
bluesl2
bluesl2's Avatar
Don't bother with the rtv, get a preformed gasket and do it the right way. If you ever have to replace that gasket again you will be glad you did it that way. Don't forget the two dabs of rtv where the front cover meets the block.
Add to bluesl2's Reputation
Old 08-04-2010, 09:32 PM   #8
PurdueGuy
PurdueGuy's Avatar
1999 SC2
1999 SC1
I tried this once on my '99, which has the same valve cover. Yeah... buy the preformed gasket. It is TERRIBLE to clean the RTV out of the groove - I think I'd rather go to the junkyard & buy a whole different valve cover than do that again.
SaturnSeries.net owner
Add to PurdueGuy's Reputation
MJO's guide to replacing valve cover gasket on Aluminum valve covers for S-series mjo How-To Library 2 04-26-2011 01:56 PM
end cover gasket,OEM or substitute? saturn94v S-Series Tech 2 04-14-2008 01:49 AM
Cam/valve cover gasket on 93 SL2 nmsaty S-Series Tech 15 02-06-2008 02:23 AM
cracked head,valve cover gasket or cam gasket leaking ???how to tell !! maestro S-Series General 11 06-04-2006 04:26 AM
FS: Valve Cover Gasket for BLACK Plastic Cam Cover, S Series jmettee Classifieds 0 11-02-2003 11:48 PM
