Old 02-10-2016, 08:33 PM   #1
Tankmalone
Tankmalone is on a distinguished road
Default Abs traction stability lights
Cold snowy day, backed my car out of the driveway to shovel. Got back in to move the car back and those 3 lights were on. Did not go off after restarting. Dirty or loose abs sensor? Wheel bearing (not hearing any noises) low brake fluid (doubt the cold would affect it) Of course it's supposed to be freezing out the next few days to make it a pita to look at. Any opinions on what to check/try? 08 saturn vue.
Add to Tankmalone's Reputation
Rate the quality of this post and help Tankmalone reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tankmalone is offline   Reply With Quote
Old 02-11-2016, 01:46 PM   #2
Default Re: Abs traction stability lights
Low brake fluid would turn on the red brake light since its used to indicate either the parking brake is engaged or low fluid level. Low fluid level is either worn brakes or a leak somewhere in the brake system.
Old 02-11-2016, 01:47 PM   #3
far2grumpy
far2grumpy's Avatar
Could be water in rear connector x408 or perhaps defective wiring harness.
There's a service bulletin - too large to post full content but Ill post thumbnail.
PM email address if you'd like a copy (left click on screen name to PM).
Old 02-13-2016, 10:51 AM   #4
Tankmalone
Awesome thanks. I'll try to check those tomorrow when it's a little warmer out.
Old 02-16-2016, 01:13 PM   #5
Hiddenlites
Hiddenlites is on a distinguished road
Hiddenlites's Avatar
1993 SC2
It could also be a wheel speed sensor. I've replaced all four corners on my Vue during my ownership. The replacement AC Delcos have outlasted the originals.
1993 Saturn SC2 75k
2004 Chevy Silverado Z71
2008 Saturn VUE Redline 175k sold 7/8/16
2013 Honda Accord Coupe
2016 GMC Acadia
Add to Hiddenlites's Reputation
Rate the quality of this post and help Hiddenlites reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Hiddenlites is offline   Reply With Quote
Old 03-26-2016, 05:45 PM   #6
Tankmalone
Where exactly are these located? I see 3 connectors by the rear passenger wheel. Tried searching but can't find the info. Parts stores haven't been much help except for trying to sell me a wheel bearing. So at least I know the codes are related to that wheel.
Old 04-06-2016, 01:14 PM   #7
tlgpe43
tlgpe43 is on a distinguished road
2008 VUE 2.2L
Hey Grumpy,
Thanks for answering this post. I have the same problem, and believe that it's the connector. Just where is the dumb thing located? My Vue is the 2008 XE.
Any help is greatly appreciated!
Tom
Add to tlgpe43's Reputation
Rate the quality of this post and help tlgpe43 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tlgpe43 is offline   Reply With Quote
Old 04-06-2016, 06:02 PM   #8
far2grumpy
far2grumpy's Avatar
Originally Posted by tlgpe43 View Post
Hey Grumpy,
Tom
Attached illustration is a bit shabby - I'll look for a better one.
Old 04-06-2016, 06:22 PM   #9
far2grumpy
far2grumpy's Avatar
Here's another thumbnail with slightly improved view of X408.
Old 04-13-2016, 04:05 PM   #10
KyleVue
KyleVue is on a distinguished road
KyleVue's Avatar
2008 VUE 3.6L
2008 VUE 2.4L
Hey folks.. My wife just hopped a curb w her right front wheel when rounding a corner, claims or doesn't think she got back wheel. Following 4 lights came on:
Traction control warn / Traction control off / ABS / Brake warn
Could it be same as illustrated above (X408 harness)? Is there one on the front wheels? Any other suggestion, otherwise? Jamming the curb would seem to imply the harness being knocked loose or broken if there's one up front too
Haven't seen her car yet. Thx very much for any feedback!
Add to KyleVue's Reputation
Rate the quality of this post and help KyleVue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
KyleVue is offline   Reply With Quote
Old 05-01-2016, 01:05 PM   #11
Tankmalone
Code is c0050-00, I cannot for the life of me figure out how to undo the connector to check it.
Old 07-02-2016, 01:11 PM   #12
cnlmustard
cnlmustard is on a distinguished road
Ok, so if I'm reading this right, there is an X408 connector that runs wires to BOTH rear wheels, correct?
We're not talking about the little connector on each rear wheel of the actual speed sensor when you change them are we?
I need to go look for that, because I've only ever cleaned each of the four speed sensor connectors near the wheel hubs.
The lights do seem to really start acting up after it rains!
Add to cnlmustard's Reputation
Rate the quality of this post and help cnlmustard reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cnlmustard is offline   Reply With Quote
Old 07-02-2016, 02:32 PM   #13
far2grumpy
far2grumpy's Avatar
See thumbnail in post #9 with note.
Wheel speed sensor wiring for both rear wheels are routed through X408 - along with GM data-bus if 2008 Vue has AWD.
Old 07-02-2016, 02:47 PM   #14
cnlmustard
I got it! I found the little red plastic thing on it can be pulled off and discarded. You have to depress a latch on the mounted female end of it, to get the male side to slide out. Sprayed with auto contact cleaner/protectant.
Lights are off again for now, we'll see if it holds.
Here's today's picture. It's 2WD.
The only other thing I've heard is to clean the connectors on the module. THAT is almost impossible to get to!
Old 07-02-2016, 06:40 PM   #15
far2grumpy
far2grumpy's Avatar
I hope that fixes the problem. The GM solution is to cut wires on either side of connector and splice wires as a bypass.
Old 07-09-2016, 12:14 AM   #16
Hiddenlites
1993 SC2
P/N for the front: 19256115
Rear: 96626080
I found them on Amazon.
1993 Saturn SC2 75k
2016 GMC Acadia
Traction Control Issue/Electronic Stability Light Smokey 2008 Vue 0 01-13-2016 10:32 AM
No ABS or Traction Control and No lights either.... Deep6 L-Series General 22 02-13-2015 10:25 AM
2008 Vue Traction/Stability Control schnabel1952 Vue Tech 3 05-16-2010 11:11 PM
traction control, and ABS lights came on? scoutinkeith 2008 Vue 2 12-30-2009 12:41 PM
Service Stability/Traction Control seankiely Relay Tech 0 11-15-2009 07:25 PM
