Old 04-05-2007, 06:18 PM   #1
97SatGuy
97SatGuy is on a distinguished road
Default Best place for ground wire
Hey guys, I have a 97 Saturn S2. I am hooking up my 2 12' Subs and need to know where the best place for the ground wire to go is. I have everything else ready to go, but i cant do anything untill the ground is ready. any help would be greatly appriciated.
97SatGuy is offline   Reply With Quote
Old 04-05-2007, 06:28 PM   #2
Rusty
Rusty is on a distinguished road
Rusty's Avatar
Default Re: Best place for ground wire
i drilled and tapped a hole in the side of the spare tire well... you can put a small hole in the carpet and run the wire through it and into the tire well... just make sure you tap the hole so you can put a small screw in it. there will only be one or two threads, so dont over tighten...
Rusty is offline   Reply With Quote
Old 04-05-2007, 07:01 PM   #3
BobbyP
BobbyP's Avatar
2006 VUE Red Line
2007 SKY
On my SC I ran my ground back to the negative on the battery. Ran both the positive and negative with a stranded 30g cable. I fused it in the UJB Underhood Junction Box.
2006 Black VUE Red Line - Now running iOS 14.7 beta
Old 04-06-2007, 02:24 AM   #4
quiksc2
quiksc2 has a spectacular aura aboutquiksc2 has a spectacular aura aboutquiksc2 has a spectacular aura about
quiksc2's Avatar
2002 L-Series 3.0L Sedan
I grounded mine to the trunk pan. Works great. Others have done it this way, too. How many watts does your amp claim to put out?
If I wanted ride quality, I would drive a Cadillac. If I wanted to be a sheep, I would drive something that says Vtec on the side of it...
DCS
quiksc2 is offline   Reply With Quote
Old 04-06-2007, 02:27 AM   #5
Uzzy
Uzzy's Avatar
2002 SC1
I grounded mine to the trunk pan too. There's some bolts under the carpet near the bumper that should work. You night have to do some scraping/grinding to get it right though. But not much.
Aut viam inveniam aut faciam
Old 04-06-2007, 03:37 AM   #6
quiksc2
quiksc2's Avatar
I just drilled a hole, wire brushed around it, used those star washers, and torqued down a nut and bolt.
DCS
Old 04-06-2007, 03:39 AM   #7
RZRIvan
RZRIvan is on a distinguished road
2000 SL
There is a bolt holding the bracket for the trunk right behind the speaker rack. This bolt already has pressure on it from the weight of the trunk and the "tensioner" bar so it gave me a pretty good ground.
RZRIvan is offline   Reply With Quote
ground wire question bigbfarm S-Series Tech 7 03-30-2009 01:16 PM
ground wire upgrades petdmc S-Series General 13 04-18-2007 04:13 PM
Where to Ground Wire ? tenn734 S-Series Mods 5 12-23-2005 12:22 PM
Ground Wire Questions lpradiohead S-Series Tech 7 01-16-2005 12:34 PM
No place to ground amp in trunk robblaw S-Series Tech 5 06-06-2003 03:41 PM
