Old 09-02-2006, 01:04 AM   #1
mordo2
mordo2 is on a distinguished road
Default rebuild mp7 transmission, Saturn TAAT transmission, Locks up in reverse, help
I rebuild my transmission in my 1999 sl2, Vehicle shift well in all forward gears, but when I shift it into reverse, it appears to want to go forward, and locks up. I read in another form that someone had the same problem, and found that they installed a part backwards. I removed the transmission again, and went through it, and I can't see where I made a mistake. Any advise?
mordo2 is offline   Reply With Quote
Old 09-02-2006, 06:14 PM   #2
Dr B
Dr B is on a distinguished road
Dr B's Avatar
1992 SL2
1993 SL2
Default Re: rebuild mp7 transmission, Saturn TAAT transmission, Locks up in reverse, help
If it is going forward in reverse ,then there must be some problem with the
forward /reverse servo ,or the related gears that the shift fork engages
otherwise there is not enough pressure ,to move the servo piston enough
or some binding in this area ,!
Can you push the shift fork into the reverse position ?
does it snap back to forward range ,when released ?
Have A Great Day , it is YOUR choice !
Dr B is offline   Reply With Quote
Old 09-03-2006, 01:08 AM   #3
From the service manual.
Complaint
Transaxle Binds in Reverse and Creeps Forward in Neutral
Clutch Clearance too tight.
Possible cause
Clutch plate tangs not aligned to gear hub.
Check clutch clearance and repair as required.
Correction
Inspect all gear/hub assemblies for proper engagement into clutch plates.
Complaint
Transaxle Binds Up in Reverse
Possible cause
Damaged or rolled input hub seal rings.
Correction
Remove end cover and inspect input hub seal rings.
Old 05-22-2016, 09:17 PM   #4
Michael2453
Michael2453 is on a distinguished road
2001 SL2
WHere is the best place to get info on rebuilding a 2001 TAAT? I'm particullarly needing to know the checkball locations of checkballs in VB.
Michael2453 is offline   Reply With Quote
Old 05-22-2016, 09:32 PM   #5
You purchase the latest version of the TAAT manual, http://www.ebay.com/itm/TAAT-Transmi...lVQncx&vxp=mtr
You can use the TAAT section of any 93-02 FSM which usually sells for 20.00. The used car manual places have these.
Old 05-23-2016, 09:28 AM   #6
SRGW
SRGW is a splendid one to beholdSRGW is a splendid one to beholdSRGW is a splendid one to beholdSRGW is a splendid one to beholdSRGW is a splendid one to beholdSRGW is a splendid one to beholdSRGW is a splendid one to behold
SRGW's Avatar
1997 SL1
Post Re: rebuild mp7 transmission, Saturn TAAT transmission, Locks up in reverse, help
Will this help??
1995 SL1 222,160 Well Oiled!!
1997 SL1 54,100 Just A Teenager!!
CHECK YOUR OIL!!
MP7 Transmission Air Pressure Test ports? bbelongia S-Series Tech 6 07-17-2009 04:24 PM
MP7 TAAT Rebuild Kit Jim_SNJ S-Series General 1 04-25-2009 11:33 PM
Transmission Problem SL2 - MP7 Don Jamison S-Series Tech 2 12-12-2008 09:59 AM
looking for an exploaded view of a Saturn Taat transmission. mordo2 S-Series Tech 13 09-02-2006 12:48 AM
Identifying MP7 or MP6 Transmission Bryan3 S-Series Tech 0 10-15-2005 08:46 AM
