Old 10-17-2005, 12:02 PM   #1
johnyrrr
johnyrrr is on a distinguished road
1997 SW2
Roll Eyes How much coolant in the if I drain the radiator
Hi guys this site rocks, I just drive my new 97 SW2 home on Saturday and after reading this site last night I am going to put in a new ECTS. the coolant looks old and I figured I might as well change out the coolant when I do the sensor, so I am wondering if I drain out the radiator when I do the sensor how much is going to come out.
johnyrrr is offline   Reply With Quote
Old 10-17-2005, 12:10 PM   #2
BarnOwl
BarnOwl's Avatar
Default Re: How much coolant in the if I drain the radiator
The rated capacity for my '96 is 7 quarts. Probably pretty much the same for a '97.
Old 10-17-2005, 12:15 PM   #3
PeteB
PeteB is on a distinguished road
PeteB's Avatar
2002 L-Series 3.0L Sedan
1994 SC2
You'll lose practically no coolant when you change the ECTS, so you don't need to hold off if you're short of time for the whole job.
PeteB is offline   Reply With Quote
Old 10-17-2005, 01:52 PM   #4
alleninpa
alleninpa's Avatar
2009 AURA XR
1999 SL1
There is a drain bolt on the engine, just below the lower coolant hose. Unscrew this and drain the block. The block holds much more coolant than the radiator does.
Radiator drain plug wishihadacamaro S-Series Tech 6 11-16-2008 12:27 AM
radiator drain valve GROVERBOY S-Series General 11 09-29-2008 01:00 AM
radiator drain valve saturnsctwo S-Series General 13 05-12-2007 04:58 PM
Radiator Drain _PuNiShEr_ S-Series Tech 5 04-03-2006 05:53 PM
Radiator drain problems maracle Miscellaneous Tech 3 07-18-2004 07:50 PM
