Old 07-04-2005, 08:18 PM   #1
SaturnRaycer
SaturnRaycer is on a distinguished road
SaturnRaycer's Avatar
2008 Astra XR
Default How to drain the coolant completely?
I'm want to change the coolant in my 2002 L200 w/2.2 Ecotec engine. I crawled under the car (once safely perched on jack stands) and could not find the radiator drain. The lower hose seems to be about 1/4 of the way up one of the radiator tanks, but no radiator drain. I also looked for a block drain and didn't find one in the obvious place which would be on either the front or back of the block just above the oilpan. I did find something that appears to be a drain bolt on the front, behind the intake manifold and directly above the starter.
Am I missing something, or is the General so confident that their Dex-Cool will out-live the car? I just found an earlier post describing removing a front cradle splash shield to locate a drain.
Use a flat blade screwdriver or pliers to open radiator drain valve and drain coolant. Approximately 3.5 L (4 qts) of coolant can be drained from the radiator. Additional coolant will remain in some cooling system components
How do I get the rest of the coolant out?
SaturnRaycer is offline   Reply With Quote
Old 07-04-2005, 10:42 PM   #2
insaneboi
insaneboi is on a distinguished road
insaneboi's Avatar
2000 L-Series 3.0L Wagon
Default Re: How to drain the coolant completely?
According to Haynes, you need to remove the under-vehicle splash shield? Perhaps this is blocking it. The illustration shows a drain plug on the side of the radiator.
As for an engine block drain plug, there is no mention of one in haynes, so who knows on that.
insaneboi is offline   Reply With Quote
ls v6 coolant drain tlsv6 L-Series Tech 2 10-26-2009 11:08 PM
Coolant Drain Plug Fox Slaughter S-Series Tech 7 09-19-2009 12:01 AM
How much coolant in the if I drain the radiator johnyrrr S-Series General 3 10-17-2005 01:52 PM
Block drain (coolant) question.... gm7 S-Series Tech 11 05-22-2004 09:30 PM
coolant drain plug? gary078 S-Series Tech 1 03-07-2004 01:01 PM
