Old 02-02-2005, 11:16 PM   #1
beensmoked
beensmoked will become famous soon enough
2001 L-Series 3.0L Sedan
2002 L-Series 2.2L Sedan
Default Sunroof Drain Plug
Can somebody tell me exactly where the Sunroof drain plug is. They said the reason for the leaking on right right side of my car was caused by that. I was wanna look at it myself
beensmoked is offline
Old 02-03-2005, 02:18 AM   #2
hugh
hugh will become famous soon enough
Default Re: Sunroof Drain Plug
Are you sure they didn't say that the drain was plugged? I would think that the last thing you would want to do is put a plug in the sunroof drain.
Most owners handbooks stress need to periodically check sunroof drains to make sure NOT plugged.
When I took delivery of my 2004 L300.3,one of things I was told was that if I parked outside to make sure to check drains freqently as sunroof does not make a perfect water tight seal because of the material used for seals. Hard to believe so I parked car,made sure tracks were dry,closed sunroof and put hose on it for a few minutes. After letting car sit for 15 minutes,I dried around edge,opened roof and sure eneough,there was traces of water on tracks.
hugh is offline
Drain Plug Leak The Critic S-Series Tech 11 01-11-2009 08:57 PM
Radiator drain plug wishihadacamaro S-Series Tech 6 11-16-2008 12:27 AM
where is the oil drain plug? Ruben Alonzo Relay General 2 03-08-2008 07:48 PM
coolant drain plug? gary078 S-Series Tech 1 03-07-2004 01:01 PM
Oil Drain plug cjm1719992002 Ion Tech 1 12-10-2003 09:19 PM
