Old 11-11-2004, 02:26 PM   #1
sportster64
sportster64 is on a distinguished road
Default "Trunk open" light keeps coming on
2001 L200. The "trunk open" light keeps going on and off on my L200. The trunk is closed. It seems like the trunk lid must need adjusted. I screwed the two ajusters all the way in on the rear lid - still didn't fix it. Is itpossible the latch itself that is causing the issue ?
sportster64 is offline
Old 11-11-2004, 03:11 PM   #2
lostwages_ls2
lostwages_ls2 is on a distinguished road
lostwages_ls2's Avatar
Default Re: "Trunk open" light keeps coming on
If you look closely, you will see a switch lever inside of the latch mechanism. It is probably bent.
Your Honor Student is merely a pawn in my Min Pin's diabolical world domination plot.
Obey the Min Pin
lostwages_ls2 is offline
Old 11-15-2004, 06:22 PM   #3
David
David is on a distinguished road
2002 L-Series 2.2L Sedan
I would also take a look at the U shape bar that triggers the trunk latch. Make sure that the trunk latch is lined up properly. Enough trunk closures and this will get loose and throw your alignment off. This may be what bent your switch lever inside the latch.
David is offline
Old 11-15-2004, 07:08 PM   #4
socketz
socketz is on a distinguished road
socketz's Avatar
Odd. I've had this happen to me once or twice recently and I discounted it as being caused by gobblins in the trunk.
Once I even pulled off the road to close the trunk ....only to find that it was closed.
Seems to be the worst going out of my neighborhood up the big hill.
But it doesn't happen always. Maybe 1 in 10 trips up.
socketz is offline
Drivers' door stuck as "open" - Help!!!! Naru S-Series General 4 12-23-2009 01:04 PM
How to seal a trunk + disble the trunk open light? lopoetve S-Series Tech 13 08-20-2008 04:13 AM
Will unplugging O2 put "warm" obdII car in open loop?? tgferg67global S-Series Tech 1 06-24-2005 05:30 AM
Tach needle "bounces" while in neutral coming to stop. auxmike Miscellaneous Tech 6 02-06-2003 11:08 PM
Open exaust causing engine "miss"????? Jon94SoLo2 S-Series Tech 4 05-21-2001 06:50 PM
