Old 05-21-2004, 07:35 AM   #1
gm7
gm7 is a jewel in the roughgm7 is a jewel in the roughgm7 is a jewel in the roughgm7 is a jewel in the rough
gm7's Avatar
2009 VUE Red Line
Default Block drain (coolant) question....
Recently, I replaced the Dexcool in my '01 SC2 as part of PM.
Doing so, I drained the radiator and the block and emptied the expansion tank. I now have a very slight leak from the block drain after replacing the bolt...a quarter size (small) puddle shows up under the car after driving it for a while after the system builds pressure. For those that have removed the block drain, it is a 10mm head, one inch long bolt that is located under the thermostat. Removing took quite a bit of torque...was surprised in fact...had to lean on the rachet...presume it was torqued tight to prevent leakage or coming loose due to vibration.
I likely did not retorque it that tight as it threads into aluminum.
Question is...anybody else know about this?...once the seal is broken for this drain...any leakage issues? Is it an advised practice to put something around the washer like an RTV when retorquing it?...or perhaps replacing the sealing washer? I don't want to go to higher torque if unnecessary...I tightened it up pretty good...but apparently some Dexcool, a small amount is leaking by the threads and head of the bolt when under pressure.
Thanks for any advice,
George
gm7 is offline
Old 05-21-2004, 09:30 AM   #2
bigbird
bigbird is on a distinguished road
bigbird's Avatar
Default
Last time I did an S coolant change, I seem to recall a metal washer on the drain bolt. If no one can give you a better answer, I'll check the FSM when I get home.
bigbird is offline
Old 05-21-2004, 10:04 AM   #3
gm7
gm7's Avatar
2009 VUE Red Line
Default
Thank you BigBird. Yes there is a large flat washer on the coolant drain plug under the t-stat. Mine is weeping, and wonder if I should coat the threads or underside of the washer and reinstall the bolt. Just don't want to add needless high torque if there is a more proper solution.
Thanks for checking the FSM..if they have a torque spec for that bolt that would help as well,
George
gm7 is offline
Old 05-21-2004, 10:10 AM   #4
amazinghl
Default
Get another drain bolt?
00 Insight 72mpg
amazinghl is offline
Old 05-21-2004, 10:58 AM   #5
gm7
gm7's Avatar
2009 VUE Red Line
Default
nothing wrong with the bolt...thread and head are perfect....just leaks...lol.
gm7 is offline
Old 05-21-2004, 11:26 AM   #6
bigbird
bigbird's Avatar
Default
Is the washer crushed? Is there a nick on the machined part of the block where the washer seats? I know the torque on the drain bolt is not excessive; it's steel on aluminum so you don't want to overtorque. I would suggest trying a thin nylon or composite washer against the block, then the metal washer, then the bolt. Don't torque over 10 ft.lbs to start.
bigbird is offline
Old 05-21-2004, 11:34 AM   #7
gm7
gm7's Avatar
2009 VUE Red Line
Default
will need to pull it off and look at it under a glass to see. To the naked eye it looked perfect...may reverse the washer as it may have take on some concavity due to torquing. I am very focused on torques...would say I did not exceed 10 ft-lbs going back on...break away torque however was perhaps 3X's that or very high for this small bolt.
Thanks,
George
gm7 is offline
Old 05-21-2004, 02:44 PM   #8
Bill Murray
Bill Murray is a jewel in the roughBill Murray is a jewel in the roughBill Murray is a jewel in the roughBill Murray is a jewel in the rough
2007 ION-2 Quad Coupe
Default
Loc-Tite PST (Pipe Sealer w/ Teflon) is the technician's friend on these type joints.
http://www.loctite.com/int_henkel/lo...d=114&layout=3
Bill Murray is offline
Old 05-22-2004, 12:00 AM   #9
bigbird
bigbird's Avatar
Default
if they have a torque spec for that bolt that would help as well, George
I just checked the FSM for the drain bolt torque. Were we wrong! 26 ft lbs. That's more than the spark plug torque!
bigbird is offline
Old 05-22-2004, 02:33 AM   #10
gm7
gm7's Avatar
2009 VUE Red Line
Default
Thanks Bigbird and Bill Murray. So happens I have some Loctite PST on hand so will give it a try and BB I too am suprised about the torque of the coolant plug...I need to tighten mine a bit. 26 ft-lbs seems correct based upon breakaway torque which I felt excessive for this size fastener into aluminum but perhaps it needs that level of torque to adequately seal with 15 psi of system pressure. Hope this helps others with their coolant replacement.
Thanks a lot guys,
George
gm7 is offline
Old 05-22-2004, 10:23 AM   #11
Luke
Luke's Avatar
Default
[quote]Fm George[/b]
Whow.....very good piece of analysis.
Luke is offline
Old 05-22-2004, 09:30 PM   #12
wolfman
wolfman's Avatar
Default
Good ole Telfon Tape pipe thread sealer (available in plumbing supply section of any hardware store) can be used as well and is easy to deal with.
wolfman is offline
ls v6 coolant drain tlsv6 L-Series Tech 2 10-26-2009 11:08 PM
Any fix for leaking engine block drain bolt? p-ROCK S-Series Tech 10 02-09-2009 01:32 PM
Where is the drain plug screw under the engine block for draining the coolant? foo S-Series General 2 04-08-2008 06:50 PM
stripped threads on block coolant drain hole geartooth94 S-Series Tech 13 01-05-2005 01:12 AM
Where is my block drain?? jasonpopnc S-Series Tech 3 02-08-2004 12:17 AM
