Old 02-24-2014, 04:26 PM   #1
kd183
kd183 is on a distinguished road
Default What relays control the transmission shifter on an automatic transmission
I was wondering what relays control the shifter in a 2000 ls Saturn. because when i press on the break pedal i can hear the click but sometimes i don't.
kd183 is offline   Reply With Quote
Old 02-25-2014, 11:13 AM   #2
s3nfo
s3nfo's Avatar
2001 L-Series 3.0L Wagon
Default Re: What relays control the transmission shifter on an automatic transmission
That's probably the brake interlock, not a relay, a mechanical linkage that prevents you from shifting out of park unless the brake is pressed.
Jerry N
Groucho Marx
Automatic Transmission shifter is loose through the gears, check engine light is on. Petroleum Astra Tech 8 10-09-2017 10:35 PM
sticky/stuck gear shifter - automatic transmission strnlvr S-Series General 5 07-02-2012 08:42 PM
1997 sl2 automatic transmission shifter cable problems rosita1mariela S-Series General 1 02-29-2012 09:25 AM
Need help with automatic transmission lfbs01 S-Series Tech 4 12-21-2007 09:11 PM
Transmission Relays darse S-Series General 4 04-26-2006 03:17 PM
