Old 09-20-2011, 07:52 PM   #1
rustydrip
rustydrip is on a distinguished road
Default sun roof drain cloged
water on floor of drivers and passenger side by the doors in front. some one said to me it is the drain from the sun roof. please help me. give me an easy fix.
rustydrip is offline   Reply With Quote
Old 09-20-2011, 11:01 PM   #2
XRL
XRL's Avatar
2004 VUE Red Line
Default Re: sun roof drain cloged
Find an air compressor and shoot a buncha air into the drain holes. They're in the corners of the moonroof track.
Old 09-20-2011, 11:09 PM   #3
far2grumpy
far2grumpy's Avatar
There are no easy fixes for a Saturn owner ... we like it tough.
See post # 9 of following thread for sunroof drain information:
http://www.saturnfans.com/forums/sho...d.php?t=147772
You could also be getting water from the fresh air intake system. Open the cabin air filter cavity and make sure its not full of water.
I recall a service bulletin to check for water intrusion around door speakers.
You may have to blast the car with garden hose while monitoring for leaks.
Old 09-20-2011, 11:55 PM   #4
Zacrazy
Zacrazy is on a distinguished road
Zacrazy's Avatar
2002 VUE 2.2L
I went throught the same thing a while back after moving the front crossbar on the roof rack. I thought I had screwed up. After spending a lot of money at the body shop to have the roof rack system reinstalled and re sealed they found out it was just the sunroof drain so they blew it out for me. Bad news, the next time it rained I had the same wet floor again, this time was even worse. There is no clip or adhesive on the drain tubes which attach to the drain ports on the corners of the sunroof trough (trawf). When the idiot at the body shop blew out the clog he blew the drain line off of the drain port. I had to remove the visors and pull down the headliner to find and fix that problem. So, be careful if you blow out the drain tubes. Good Luck!
Zacrazy is offline   Reply With Quote
Old 09-29-2011, 11:01 AM   #5
TheClyde
TheClyde is on a distinguished road
That answer is exactly right. My wifes Vue has been in twice for the clogged drain. The mechanic said that if you try to blow out the tubes they will dislodge and you have a bigger problem. We paid the $700 to have it fixed and now cover the car at night to keep debris out of the channels.
TheClyde is offline   Reply With Quote
Old 09-29-2011, 11:14 AM   #6
BobbyP
BobbyP's Avatar
2006 VUE Red Line
2007 SKY
Test your drains with water and after you are sure they are not leaking, pour a dose of bleach in all 4 drain tubes. Then flush them with water.
2006 Black VUE Red Line - Now running iOS 14.7 beta
Old 06-25-2014, 03:39 PM   #7
Curly Gurlz
Curly Gurlz is on a distinguished road
Question Re: sun roof drain cloged
If debris has gotten into the hose via the top, wouldn't the air compressor force the debris further into the hose if it's clogged at the top?
If I use an air compressor on the hose from the bottom, wouldn't that force the debris out at the top?
Has anybody used the air compressor to force air through the hose from the bottom (to force the debris back out whence it came)?
Curly Gurlz is offline   Reply With Quote
Old 08-05-2015, 01:33 PM   #8
VTchemist
VTchemist's Avatar
Default Sunroof drain hose and headliner removal for VUE
Here is a video I found on fixing a leaking sunroof drain in the VUEs (02-07).
https://youtu.be/mD_dUgZbCyA
My sunroof was leaking on the passenger's side.
The removal and fix are straightforward. You will need a 9/32 nut driver or small socket set (1/4") to remove the cover for the pillar.
I used hose clamps instead of zipties and super glue.
My drain was also plugged. With the reassembled rubber connector, I was able to clear the drain. Kinda like playing the trumpet...
Old 08-05-2015, 05:13 PM   #9
circles6
circles6 is on a distinguished road
2004 VUE 3.5L
I HATE sunroofs. When I took delivery of my 04 from the dealership they detailed the interior and washed it. Someone must have done the wash with a pressure washer and hit the sunroof area so hard it blew the front drain hoses off their connectors. Took a good week in the garage steam cleaning every day and blowing fans under the carpet
circles6 is offline   Reply With Quote
Old 08-26-2015, 12:52 PM   #10
newbievueowner
newbievueowner is a jewel in the roughnewbievueowner is a jewel in the roughnewbievueowner is a jewel in the roughnewbievueowner is a jewel in the rough
2006 VUE Red Line
Has anyone tried the weed eater cord down (or up) the tube trick? Should help dislodge any foreign material that may be in the drain tube.
Saturn Vue: The 250 HP tupperware
newbievueowner is offline   Reply With Quote
Sun roof drain cleanout porchdog Outlook General 0 06-19-2010 08:52 PM
Roof rack for 2007 Vue w/o Chrom Roof Rails ewmaher Vue General 11 06-16-2009 09:41 AM
how do you clean out the drain tubs in a 04' Q2 sun roof jhutch2115 Ion General 2 05-21-2007 08:19 PM
Missing drain tube for sun roof NcNghtStkr S-Series Tech 7 09-15-2006 11:27 PM
Panoramic roof......twice the cost, twice the trouble of a regular roof? comcardi Aura General 10 08-04-2006 11:31 PM
