Old 12-05-2009, 03:51 PM   #1
srella
srella is on a distinguished road
Default subwoofers
hey i drive a 2002 sc2 and i'm getting from a friend 2 12" kickers amp and wiring. i was wondering if anyone knew a good site where they tell you step by step how to install them yourself
srella is offline   Reply With Quote
Old 12-05-2009, 09:54 PM   #2
PaulN64
PaulN64 is on a distinguished road
2001 SL2
Default Re: subwoofers
Depends, how much experience do have in installing car audio? Coming from my experience as a former installer, don't take it on unless you have some experience or someone with experience to help you install it. Although, I did enjoy having to fix those since it's double the charge.
2001 SL2<-- daily driver
2006 Corvette Z06<-- fun car
www.sounddomain.com/id/2004z06
PaulN64 is offline   Reply With Quote
Old 12-06-2009, 04:36 PM   #3
Plug in RCA cable to receiver, run wire down passenger side door sills.
Run 10g (or whatever size wire your amp calls for) fused power cable from battery through grommet all the other wires use to go through the firewall (unless automatic then just poke out clutch hydraulics plug) and run up the driver side door sills to trunk.
Connect amp to ground (I use one of the 12mm bolts holding the rear bumper on), then power. Then connect RCA(s) to amp, then amp to woofer(s).
Tags
audio, sc2, subwoofer
Amplifiers and subwoofers Eds95sc2 S-Series General 6 08-31-2009 03:27 AM
Powered Subwoofers mwhite Vue General 24 06-30-2007 02:31 AM
Subwoofers and Rims QuadStar Ion General 5 04-18-2007 10:35 AM
Concealing subwoofers DerDrache Vue General 43 09-09-2005 08:31 PM
Subwoofers and Space Efficiency MyL300 S-Series Mods 21 03-03-2003 06:40 PM
