Old 09-18-2009, 03:18 PM   #1
Fox Slaughter
Fox Slaughter is on a distinguished road
Fox Slaughter's Avatar
Default Coolant Drain Plug
2001 SC2 Automatic.
Trying to change the water pump. I need to drain the coolant, but the drain plug is like a forward only screw. If you try to unscrew it, the screwdriver just slips off. I tried putting channel locks on it. Is there any easy way to do this?
I'll be sitting at my desk
With a gun in my hand, wearing a bulletproof vest singing
"My, my, my, how the time does fly, when you know you're going to die
By the end of the night."
Fox Slaughter is offline   Reply With Quote
Old 09-18-2009, 03:23 PM   #2
Fox Slaughter
Default Re: Coolant Drain Plug
Nevermind got it with the channel locks.
Old 09-18-2009, 03:59 PM   #3
rc1488
There are two exits for coolant to be drained. Under the thermostat with a 10mm socket, or the plastic drain plug on the radiator. The one under the thermostat needs to be done if your doing the water pump
Old 09-18-2009, 05:47 PM   #4
Fox Slaughter
I just drained the radiator then when you take the water pump the rest of the coolant comes out.
Old 09-18-2009, 05:54 PM   #5
PurdueGuy
PurdueGuy's Avatar
1999 SC1
The radiator drain usually has one of two style drain plugs - one with a big fin/handle, and one with a square hole that fits a 1/4" ratchet head perfectly.
SaturnSeries.net owner
Old 09-18-2009, 06:37 PM   #6
Fox Slaughter
Darn it, could of used a 1/4" ratchet then.
Old 09-18-2009, 07:46 PM   #7
mattelderca
mattelderca will become famous soon enough
mattelderca's Avatar
1998 SC1
1996 SL
Darn it! Would have thought you knew that!
2000 SL1 freebie, my sons DD
1998 SC1 still running, FOR SALE cheap!
1996 SL, GONE but not forgotten
2005 Generic Silver Minivan (Kia Sedona)
2009 Nissan Sentra 2.0S
mattelderca is offline   Reply With Quote
Old 09-19-2009, 12:01 AM   #8
saturnsctwo
2001 SC2 Automatic.
first squirt it with silicone lube & then stick a 1/4" socket drive in it & turn it counter clockwise. it turns & comes out. take it easy as it's plastic & easy damaged...
the drain plug under the stat housing doesn't drain much coolant maybe a cupfull at best. not worth taking off really...
Please help--can't find coolant drain plug, 04 ION bhobishshot Ion Tech 12 01-07-2017 04:10 PM
Coolant drain plug leakage wishihadacamaro S-Series Tech 8 01-03-2009 01:03 AM
Gawh! Was anybody able to remove coolant drain plug for SL2(2002)? latestgood S-Series Tech 13 11-14-2008 08:42 PM
Where is the drain plug screw under the engine block for draining the coolant? foo S-Series General 2 04-08-2008 06:50 PM
coolant drain plug? gary078 S-Series Tech 1 03-07-2004 01:01 PM
