Old 07-05-2009, 09:54 PM   #1
Luma46
Luma46 is on a distinguished road
2007
Default AT5 transmission oil cooler
I am little bit confused here. Does the 3.5l Vue have an AT oil cooler? I understand it is an option or part of a towing package with the Honda Pilot. I am towing a 2200# trailer (probably at least 2500# loaded) with my Vue and I am wondering if I should be looking at some additional AT oil cooler.As well, any recommendation on using the D or I gear when towing?
Thanks,
Lumir
Luma46 is offline   Reply With Quote
Old 07-05-2009, 10:50 PM   #2
far2grumpy
far2grumpy's Avatar
Default Re: AT5 transmission oil cooler
Thanks,
Lumir
There's towing information in the owner's manual ... I've attached extract as pdf if you don't have.
Also, extensive trailer towing changes all service requirements for the 3.5 engine Vue ... including reducing timing belt change from 100,000 miles to 50,000.
The severe service data is also in owner's manual.
Old 07-06-2009, 01:09 PM   #3
newbievueowner
newbievueowner is a jewel in the roughnewbievueowner is a jewel in the roughnewbievueowner is a jewel in the roughnewbievueowner is a jewel in the rough
2006 VUE Red Line
There is a small AT oil cooler in the rad. It is very small though. If you plan on doing towing with it (especially in the summer), I would add a little 8x10x3/4 thk oil cooler after the small stock one in the rad. It can't hurt (ie: added safety for $75). I added a B&M one to mine and after driving you can hold your hand on the outlet side of the cooler without getting burned (just don't let it idle for a long time because without air flow there is no cooling and it will get hotter). They really do work well when moving.
newbievueowner is offline   Reply With Quote
Old 07-07-2009, 09:46 AM   #4
Tom92SCm
Tom92SCm's Avatar
2004 VUE 2.2L
I have an AT cooler on my Mazda Protege. I don't tow with it at all. In my opinion, all automatics can benefit from additional cooling. Heat is one of the main causes of automatic transmission failures.
I've completely bypassed my factory AT cooler (in the bottom of the radiator) and run all the fluid through an auxilary cooler mounted in front of the AC condenser. If you live someplace that sees really cold temps in the winter, then keeping the factory AT cooler inline will help to warm the fluid- while heat is a killer of transmissions, the fluid does need to be a little warm to work well.
Not a Saturn.
Old 07-10-2009, 10:02 AM   #5
Luma46
2007
newbievueowner, couple questions on this AT oil cooler:
*what brand of a cooler and where did you buy it
*how did you connect it - did you split somewhere the return line, did you need any special fittings?
Old 07-10-2009, 08:43 PM   #6
newbievueowner
2006 VUE Red Line
Luma, I think this was the kit I used: http://www.summitracing.com/parts/BM...4/?image=large
The reason I say 'I think' is because they have this tranny cooler kit listed as a 11"x7"x1.5" kit with 3/8" inlet and outlet ports. I think they made a mistake in the online posting for 3 reasons:
1) the 3/8" ports coolers are 3/4" thick while the 1.5" thick coolers have a 1/2" NPT fitting (I have both coolers). The 1 1/2" thick cooler would be way over kill for this application!
2) the 1 1/2" thick cooler costs more than this one
3) B&M doesn't make 'kits' with the 1 1/2" thick cooler. They are stand alone units.
To answer your other questions: I used a mini tube cutter, spliced into the supply and return lines and added an external tranny filter for $15 while I was at it (didn't want the chance of getting any contaminants in the tranny after the update). I just flared the ends slightly on the cut portions of the tube so there was no possibly of the hose/clamp slipping off and cleaned up the flares with some sand paper to remove any burrs/sharp edges. When you flare the supply & return times from the tranny, you want to put a little piece of a small rag to keep debris out. Just don't push it in TOO far or it will be more difficult to get out.
Everything came in the kit. I didn't really have to buy anything extra (with maybe the exception of 6 small hose clamps - I can't remember).
I will take a pic showing the mounting but won't be able to do that until Sunday (I have no camera at this time). It is an easy install though once you know how/where to mount it and route the lines. Probably 2-3 hrs max.
Transmission cooler for 3.5 V6 Polished 2007 Vue Tech 6 10-01-2009 09:42 AM
Transmission Oil Cooler Line Seal Repair Eazy340 Vue Tech 1 09-10-2008 04:51 PM
Transmission cooler? Allwhitevue Vue General 9 08-10-2007 12:32 AM
3.5L Transmission Cooler GearGuy Vue Tech 14 02-10-2006 02:33 PM
transmission cooler shaner123 S-Series General 13 01-17-2006 11:04 AM
