Old 10-26-2008, 07:44 PM   #1
woonyboi02895
woonyboi02895 is on a distinguished road
woonyboi02895's Avatar
Default 97 saturn sl2 code 341 HELP
MY 97 sl2 with 198k Keeps getting 0341 code. I replaced cps sensor 3 times already and i keep getting 0341 code and car still runs great. WHy do i keep getting this code. I also cleaned coil packs and replaced wires and plugs.
woonyboi02895 is offline   Reply With Quote
Old 10-26-2008, 08:04 PM   #2
Default Re: 97 saturn sl2 code 341 HELP
You have fixed something that is not broke.
To get rid of the 341 do the following:
New NGK plugs, BKR5ESA-11. No BOSH or any other platinum plug. AC copper is OK and that is it.
New wires, mid price direct fit wires, nothing exotic.
Clean the ignition coil towers and the coil mountings. Check the How-To Library
Replace the ECTS if the installed one is not brass tipped. If you do not know, just replace it and also check the connector for any corrosion.
Old 10-26-2008, 08:54 PM   #3
woonyboi02895
I put autolite plugs in. ects replaced already. Wires replaced with ones from autozone. cleaned coil packs and Control Module. the ects wire is already new from who ever owned it before me. The code comes about every 6 months it seems like. THe car only once has acted like it was gonna stall when i stopped and hasn't done it again. ALso has the famous 97 anti theft LOL. prime fuel pump 2 times and then it seems to start right up. Should i think about new coils and new Control Module. Or just replace plugs that i first replaced when the code 0341 1st started. Auto zone cleared code this time and lets see how long it takes to come back.
Old 10-26-2008, 09:12 PM   #4
If the connector has been replaced then the splices should be soldered, no crimp connectors. Then, does your temperature gage get these readings?
If you have a DVM check the resistance between the coil towers, should be 8K. look along the side of a coil and see which end the ground trace rins to. remove the bolt and scotch brite under the head of the bolt and the ground pad on the coil. It is possible that the connector to the ICM is a bit flaky. Might want to unplug it and check for corrosion. The ICM can go bad but its an expensive part.
Old 10-26-2008, 09:17 PM   #5
woonyboi02895
Who ever owned car before me replaced the connecter and looks like its sodered. They also replaced dexcool with the green stuff Thank god. I hate dexcool. I will check the bolt and way things look under coils. Thanx for the help.
Old 10-26-2008, 09:38 PM   #6
westwind999
1999 SW1
I ended up replacing my control module when 341 wouldn't go away. I got one from a Pick-N-Pull for $20. The code hasn't come back since.
Old 10-26-2008, 10:07 PM   #7
If that does not fix it the trip to the local pick and pull as suggested by westwind999 is the next step. You really don't want to buy a new one.
Old 10-26-2008, 11:02 PM   #8
woonyboi02895
I am gonna try the pick n pull. We have a great one here in blackstone mass. Scored a very nice cd player out of a 98 sl2 that had the full install kit and only paid 25$ for it. They didn't see it in the car cause it was loaded with all the smashed parts lol
Old 10-26-2008, 11:23 PM   #9
Not a bad idea. Just get the entire ignition pack, coils and all. Look at the core of the coils and pick one where they still have plastic on them. Take a DVM and measure the tower to tower resistance, 8k is about normal.
Old 06-24-2012, 01:32 AM   #10
addemeter
addemeter is on a distinguished road
1995 SL
1996 SL
I have a 96 SL with the P0341 code but no SES light. Does that make sense? Also, (not sure if this matters) but it took about 500 miles and 10 drive cycles for the sensors to reset (it was 4 INC and 3 READY) not sure if that matters. I had previously cleared the code hoping it wouldn't come back and I could get an emissions test and a license plate. But it took so long now I am going to have to pay a late fee. Finally however the sensors reset and I got a pending code first then a regular code but the scan tool says 1 code p0341 mil light status off. WTF?
I have replaced plugs and wires about 10,000 miles ago and just recently replaced the ects (no luck with the ects).
By the way could one of you guys explain why platinum plugs are bad and how did you first find out that they caused problems. Is it in a factory service manual or service bulletin or something that haynes manuals don't delve into just curious.
addemeter is offline   Reply With Quote
Old 06-25-2012, 10:13 PM   #11
adventureoflink
adventureoflink's Avatar
been beaten to death many times, like the coolant brand wars and the oil/filter wars...
but it's due to it interfering with the waste spark system of G.M. vehicles. Funny thing -- I was watching an Eric the Car Guy video on U-tube earlier (one of his latest ones on engine preformance issues) and he also mentions using the proper spec spark plug for your vehicle.
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Old 06-25-2012, 10:18 PM   #12
It is casually mentioned in the FSM as well.
Code 341 and 731 CoreyB105 S-Series Tech 4 05-30-2009 08:20 AM
I had that old 341 code.Now new problem! financialguy S-Series Tech 6 06-14-2005 10:42 PM
1998 SL2 old 341 problem financialguy S-Series General 1 06-14-2005 12:16 AM
1996 Sl2 Diagnostic Code 341 Bart Aiello S-Series Tech 1 02-13-2004 05:48 AM
code 341 bills33 S-Series Tech 8 09-24-2003 07:24 AM
