Old 05-27-2008, 06:37 AM   #1
oldguard
oldguard is on a distinguished road
Default Water on floor boards
I have a 2001 L200 Sedan. The floorboard mats are soaking wet.
Can anyone advise how to check the drain of the HVAC system so I can see if it is backed up (and can drain it)????
Appreciate your help.
Thanks
OG
oldguard is offline   Reply With Quote
Old 06-11-2008, 08:50 PM   #2
wildwestsydney
wildwestsydney is on a distinguished road
Default Re: Water on floor boards
If you have not had any advice on this yet here is mine. I had the same problem this last weekend on a weekend getaway drive home during a heat wave. I had to turn off the AC due rising water levels in the front floor mat area. When I got home I opended up the hood and looked for any obvious problem an noticed a tube coming out of the fire wall and fiddled with it and realized this was the AC condensation drain. I unscrewed one 8mm bolt and pulled it out and a good quart of water drained out. I unplugged the drain and reinstalled. I have not driven the car since due to the fact that I am saving gas using my dual sport motorcycle to go back and forth from work but I did run the car in the drive way with the AC on and it was draining properly.
2000 LS1 154,000 miles and running tight.
wildwestsydney is offline   Reply With Quote
Old 06-12-2008, 09:17 AM   #3
oldguard
Thanks for the reply. Yep, that is what my nephew did. He shook the tube and even though it was on an incline, about a gallon of water came out. Figured something was stuck in it.
Thanks again.
OG
Water under my floor mats houstontexanfan S-Series General 24 05-19-2010 04:35 PM
Wet floor boards, is sunroof drain lines the problem? k1hog S-Series Tech 3 09-08-2009 10:15 AM
floor boards rusted at driver seat JS593 S-Series General 7 10-27-2005 03:19 PM
Floor boards in the Cargo area bend lucky64 Vue Tech 2 05-07-2005 10:12 PM
anybody else have wet floor boards? texan Vue General 7 08-05-2003 08:23 AM
