Old 01-23-2014, 08:38 PM   #1
BIGlep
BIGlep is on a distinguished road
Default 2001 Saturn SC2 H/O Alternator
Hi so I am new to using forums and this is my first car. I am looking to a fairly extensive audio build and at the end of the day I should end up running approximately 1800 watts RMS which at 14.4 volts comes out to 125 amps. I know that my saturn has a Delco CS-121 alternator based on what I have read and that it is around 90 amps. I am interested into what "style" of CS-130 alternator is needed to fit and also what kind of fab work will be necessary.
Based on this thread (can't post link, google "sc2 uprgaded alt 2002" third one down) it seems that excluding the cable it should all hook right up except that I might(??) need a custom bracket(??!!!)
The reason I ask what type is because I don't plan to get the older S series alternator, but a H/O one from DC power. They don't know my car though so I need to know what style of case is needed to fit. I would also be interested in if a CS-144 alternator can fit. Thanks.
BIGlep is offline   Reply With Quote
Old 01-24-2014, 05:56 PM   #2
BIGlep
Default Re: 2001 Saturn SC2 H/O Alternator
anybody got ideas
Old 01-25-2014, 03:09 AM   #3
The better "Iceberg" alternator bolts on '91-'02 S-Series, '97.5-'02 just needs an adapter or splicing to the older style plug.
The proper way to fix a S-Series automatic is to replace it with a manual
Old 01-25-2014, 01:10 PM   #4
BIGlep
Thanks that's what I thought. What about the weird rear flange or something, I heard that the iceberg doesn't have the special flange that our alternators have.
Old 01-25-2014, 01:44 PM   #5
anmasher
anmasher has a spectacular aura aboutanmasher has a spectacular aura aboutanmasher has a spectacular aura about
anmasher's Avatar
1996 SL2
That is correct, but you can fairly easily rig something up
anmasher is offline   Reply With Quote
Old 01-25-2014, 02:14 PM   #6
You can buy custom built CS131 alternators built with the correct end housings. If you do not have the correct end housings you will get flex in the mounting and drive belt problems. All the custom alternator shops can build you one. Look for an Automotive Electric in your area.
Old 01-25-2014, 02:15 PM   #7
Adapter plug, I believe it's the right one (none of my stored alternators have the new style plug): http://store.alternatorparts.com/partnod1w1206.aspx
Upgrade kit for CS130's: http://store.alternatorparts.com/cs1...rade-kits.aspx
Saturn appears to have used the CS130 '91-'97.5, but instead of using that style mounting they used the CS130D style mounts.
Old 01-25-2014, 02:41 PM   #8
The end bell are unique to Saturn and they are available for any of the 130 series alternators.
The CS130D is not unique to Saturn.
Old 01-25-2014, 03:29 PM   #9
BIGlep
What is entailed in making one. I do have access to some basic tools like and angle grinder and a drill press, is it just a little bar or is it complicated.
Old 01-25-2014, 07:44 PM   #10
anmasher
anmasher's Avatar
1996 SL2
^^This.
I made a bracket *(and attempted to rebuild the alternator) and the thing blew up within 2 months.
Old 01-25-2014, 09:09 PM   #11
BIGlep
So a custom bracket is out. Dang. So a custom alternator is my only choice that sucks. Do you think I could get the iceberg but use my rear housing and somehow just attach a heatsink?
Old 01-25-2014, 09:39 PM   #12
Search for a member, Pioneer Saturn for his twin alternator set up for LOUD sound. He posted pics.
VCX NANO
alternator, audio, electrical, sc2
2001 L200 - Possible Broken Belt/Alternator/AC Compressor gfunke L-Series Tech 2 09-24-2010 06:57 PM
02 saturn vue alternator kledford Vue Tech 9 02-16-2010 10:11 AM
2001 L200 alternator wiring brad6sic6 L-Series Tech 4 02-06-2009 06:29 PM
2001 Sc2 Alternator -> Interior Wire. 01SIlverSc2 S-Series Tech 4 11-14-2008 06:14 PM
'96 Saturn - Bad Alternator? Geodesic17 S-Series Tech 22 12-10-2006 08:29 PM
