Old 11-02-2011, 06:29 PM   #1
rustydrip
rustydrip is on a distinguished road
Default cloged drain lines on a 2002 vue
i HAVE HAD A PUDDLE OF WATER ON THE PASSENGER SIDE FLOOR. i WENT TO A GMC DEALER WHO IS SUPPOSED TO BE CERTIFIED ON SATURNS. THEY BLUE OUT THE DRAIN LINES. AFTER A RAIN STORM TWO DAY'S AFTER IT WAS BACK AGAIN. i HAVE BEEN BACK TO THIS DEALER 3 TIMES THE PROBLEM IS STILL THERE. I NEED TO KNOW WHERE THE ENDS OF THE DRAIN LINES IN THE FRONT. I TOOK OFF THE KICK PLATE AND TRIED TO LOOK FOR THE LINES BUT NO LUCK. PLEASE HELP ME I THINK THIS IS A PROBLEM FOR A LOT OF SUNROOF OWNERS.
rustydrip is offline   Reply With Quote
Old 11-03-2011, 11:19 AM   #2
3RedLines
3RedLines has a spectacular aura about3RedLines has a spectacular aura about
3RedLines's Avatar
2004 VUE Red Line
2004 VUE Red Line
Default Re: cloged drain lines on a 2002 vue
The drain exits behind the fender, between the antenna and the door hinge. take the splash shield from around the wheel opening and you should be able to see it.
I think you can see the tube from the inside with the kick panel off. It would be up high, near the level of the glove box.
You could have a split drain tube behind the trim around the edge of the windshield.
2007 STS-V
2006 STS 1SC
2005 STS 1SE MRC, ACC, HUD
3RedLines is offline   Reply With Quote
sun roof drain cloged rustydrip Vue General 9 08-26-2015 12:52 PM
Wet floor boards, is sunroof drain lines the problem? k1hog S-Series Tech 3 09-08-2009 10:15 AM
Clogged Sunroof Drain Lines Gumart1 S-Series General 16 07-28-2009 07:46 AM
Battery Drain on 2002 Vue jdurham Vue General 8 06-09-2005 12:24 PM
FS: injectors, drain lines, turbo manifold, wideband, etc... tristanlee85 Classifieds 4 04-26-2005 09:22 PM
