Old 04-26-2011, 06:41 PM   #1
jayfire
jayfire is on a distinguished road
Default 02 SC2 sunroof not level with body lines?
I just purchased this car and the only thing wrong with it is the sunroof. It looks like its the plastic piece in the track. The drivers side goes up a little but won't go back. When I tried closing it, I could not get the DS to go all the way down. I pulled the glass off, got both tracks all the way down and put glass back on. Now the rear part of the sun roof is lower than the body line, but the front is even. Is this right? The tracks are all the way down and all the torq bolts lined up fine, but it just doesn't look right. I just don't want it to leak, until I get it fixed. Thanks
jayfire is offline   Reply With Quote
Old 04-26-2011, 07:14 PM   #2
saturnsctwo
Default Re: 02 SC2 sunroof not level with body lines?
my 2001 sc2's sunroof panel doesn line up exactly with the roof either. it never did & my sunroof is like new with low useage. the rear of the glass panel is slightly lower than the rooftop but the rest of it lines up pretty good though.
Old 04-26-2011, 08:50 PM   #3
jayfire
What is slightly lower? Mine, before I started messing with it was level all the way around. Since I took the glass off and made sure everything was at its lowest point and put the glass back on, it is about 1/4" to 1/2" lower in the rear than the body line. If that is ok than I will be fine with it. I just do not want it to leak. Other than that, do you think that $5K was a good deal on this car with 52,000 "granny" miles on it?
Old 04-26-2011, 10:44 PM   #4
ruley73
ruley73's Avatar
IIRC the sunroof glass is adjustable.
I believe there are three torx screws on each side that attach the glass to the arms that hold it. Loosen these (not all at once), move the glass and retighten them. They are a bit difficult to get to though.
2007 Chevy Equinox LT 216K miles
2018 Chrysler Pacifica Touring L 100K miles
Old 04-27-2011, 04:41 PM   #5
jayfire
I tried moving the glass up and tightening the torq screws and it is still about 1/4" lower than the body line.
Old 04-27-2011, 05:32 PM   #6
saturnsctwo
one corner is about 3/16" lower than the body surface. i got it adjusted as good as possible, but i don't think the glass panel is exactly shaped even with the roof & that's why there's some difference. when you loosten the 6 torx head bolts inside the car there is some adjustment but not much. if yours is that much lower you must got an issue with the track or guides.
a 1/4" to 1/2" lower will leak as the glass panel weatherstrip isn't in contact with the hole in the roof. it can't be....
Old 04-27-2011, 05:39 PM   #7
SC2BuzzBomb
SC2BuzzBomb is on a distinguished road
The car is approaching 10 years old and was an economy car to begin with. If this is the worst problem on the car, consider yourself lucky! The sunroof problems on an S-series can be much worse than some body line issues.
SC2BuzzBomb is offline   Reply With Quote
Old 04-27-2011, 08:05 PM   #8
saturnsctwo
1/4" to 1/2" lower is more than simply body line issues, there's something wrong.
Throttle Body vaccuum lines FearsOfWar S-Series Tech 11 02-14-2010 10:36 AM
Wet floor boards, is sunroof drain lines the problem? k1hog S-Series Tech 3 09-08-2009 10:15 AM
Clogged Sunroof Drain Lines Gumart1 S-Series General 16 07-28-2009 07:46 AM
sunroof leaks... where do the drainage lines EXIT the car?? DJboozeAlot S-Series Tech 6 02-12-2007 11:44 PM
Throttle Body Vacuum Lines SL2Dreams S-Series Tech 6 08-07-2005 08:50 PM
