Old 07-04-2005, 11:55 AM   #1
Anjey
Anjey is on a distinguished road
1996
Default Engine swap - 99 SC2 to 2000DOHC engine - Question
I need to replace an engine in a 99 SC2.
Unfortunately I can't find the right engine.
Last time I had a 99 SC2 in my shop I searched for 2 weeks!
I do not want to go through that again and I wonder if I can put a 2000 DOHC engine in???
Please advise...
On 99 I have 4 sensors in between the engine block and firewall.
Will I be able to conect all the plugs there if I put the 2000 motor in?
Also will the 99 intake and the 99 exhaust match the head of 2000?
I have like 10 different DOHC engines on a local yard, mostly 2000 and up - but NONE from 99! Is there anything specific I should look at?
I know I need to replace the intake, because these are totaly different.
But what about the temperature sensor and the rest of these sensors down there on the block? Is the timing cover the same?
Help!
Anjey is offline   Reply With Quote
Old 07-04-2005, 04:12 PM   #2
the_new_raceman
the_new_raceman is on a distinguished road
the_new_raceman's Avatar
Default Re: Engine swap - 99 SC2 to 2000DOHC engine - Question
If theyre both DOHC it should work...i think the 99/00 engines are the same.
If you dont like the tires ur on...change em...now how does that apply to life??? think about it.
the_new_raceman is offline   Reply With Quote
Old 07-04-2005, 04:35 PM   #3
Anjey
1996
Thank you for your response, however I need to be sure.
I made too many mistakes this year and some of these mistakes are still here in my yard!
Problem is they won't take the engine out to show me until I pay for it.
Most of these cars are wrecked and I just can't see what plugs and sensors are there!
Old 07-04-2005, 05:10 PM   #4
the_new_raceman
Im near;ly positive the 99/00 motors are the same but dont hold me to it.
Old 07-04-2005, 05:29 PM   #5
John97sc
John97sc is on a distinguished road
John97sc's Avatar
1991 SC
99 has the aluminum intake, the 2000 has the plastic intake
John Dalton
97 SC2
You may need earplugs when riding in my car!
John97sc is offline   Reply With Quote
Old 07-04-2005, 08:11 PM   #6
The block will be the same. If the sensors/connectors are different swap the sensors. The heads will be different. The intake has fewer hold down studs. Also the head is narrower. They revised the valve train by changing the lifters.
Old 07-04-2005, 11:36 PM   #7
the_new_raceman
my 98 sc2 has a plastic intake hose...
Old 07-05-2005, 12:55 AM   #8
wolfman
wolfman's Avatar
Allow me to restate that:
The EARLY 99' and older DOHC engines had aluminum intake MANIFOLDS
The late 99'~02's DOHC engines had plastic intake MANIFOLDS
Old 07-05-2005, 03:21 PM   #9
Anjey
1996
Does it mean I won't be able to swap the manifold? Right?
If the head is different then I won't be able to attach the aluminium manifold to 2000 head!
I hate that! What a bunch of trouble.
Why did they do that?
No respect to mechanics at all.
What about the exhaust manifold mount to exhaust?
Will this match??
Is the manifold the same or different?
Old 07-05-2005, 08:56 PM   #10
The exhaust manifold I am not sure of. The last time I had to try a retro fit I went as far as the intake and stopped there. My figuring was if you can't get the intake on then why go any further?
Old 07-06-2005, 11:11 AM   #11
Anjey
1996
True.
Thanks for advise.
I won't even try then.
97 SC2 engine swap casterman S-Series Tech 8 04-04-2008 08:17 PM
97 sc2 engine swap gettinfast S-Series Tech 2 08-22-2007 05:57 AM
SC2 Engine swap question - Please help Gbody403 S-Series General 6 05-04-2006 01:09 PM
98 Sc2 engine swap...HELP the_new_raceman S-Series General 23 02-06-2005 01:02 PM
97 sc2 engine swap, please help c_j_hazlewood S-Series Tech 10 07-18-2004 07:56 PM
